Question about Nikon Coolpix 4600 Digital Camera
Lenses on digital camera
My lenses on my digital camera is half open and won't close or open anymore than that. what can i do? Have same problem. It's not the lens cover - as that fully opens. It is the lense extending itself fully from the base of the camera.  I suspect something like a grain of sand or a gear wheel may have jamed. So have un done the screws but don't know how to  'crack' open the camera in order to inspect the innards.
  • 6,487 Answers
Yes this can be cause by a dirt or sand that accidentally went inside your lens and you really need to dismantle the camera to do that cleaning of the lens if you're really not the aware on how to do that ask for someone to do it for you...
Good luck....
Posted on Aug 10, 2008
    Genius:
  • 1,689 Answers
You may try realigning the lens assembly by hitting the side of the camera gently or gently pulling it out while nudging it sideways...sounds risky but right now my camera is just a paperweight so I figure it might be worth a shot...
    Guru:
  • 1,894 Answers
Yes its grain or sand only stuck in between the lens.
are you experienced in electronics for opening the camera?
  • dewan nafees ahmed Aug 10, 2008
    There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for digital cameras.
    They are not in english but have a lot of pictures which help with the process.
    - Bulgarian guide
    - Estonian guide
    cameras shows are of a different company. but your unit is also a similar and equivalent one.
    thank you
My samsung S1050 lense will not open or close, it is stuck half way.
forcing it closed usually ends badly...stripped or sheered gears.TRY putting pressure on the lense durring power up...if it feels like it will move let it go....next using a small jewelers screw driver try to pull the lense open ...may take a bit of playing...be patient!
Nov 11, 2014 | Samsung S1050 Digital Camera
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
Hello I have a canon IXUS 960 IS. Yesterday when I was using the camera it only closed half way when powering the camera off. Now the camera doesn't open fully and when pusing the "play" button the power...
If the outside of the lense get dirty, those small particles may prevent the lense from opening and closing 100% as nomal times. I had the same problem with my Sony. Here is what I did.
1- I cleaned the outside(sides not the lense itself) of the lense.
2- While turning the camera off, I press on the lense (up and down motion) NOT too hard for a few times untill it either retracted all the way inn or most of the way in. If most of the way in, press the lense a little harder untill it retracts 100%. If you turn it back on, it should work as normal unless some mechanical part of the lense is broken or dislocated. When it fully opens, clean up the outside of the lense and keep it always clean for normal operation.
Good Luck!!!!!!!!
Jun 11, 2009 | Canon IXUS 960 IS Digital Camera
Digtal camera
try opening it with your fingers.
mine did that before too.
just like.. push it open.
hopefully it will stay.
Oct 04, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Hey jamber716,
I am assuming you mean the lens cover is half open and won't close or open. You could try blowing compressed air into the lens to try and dislodge whatever is making the lens cover stick. If that doesn't work I would have the camera looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they should be able to send it out to an authorized service center. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 29, 2008 | Nikon Coolpix 4600 Digital Camera
Unscrewing lenses
Hello toccata, It sounds like your lens mount is cross-threaded. Have you gotten a lens off and looked closely at your camera lens threads. Are they crunched together. You may need to get your cameras lens mount replaced and check all your lenses and see if the threads aren't cross threaded. If a lens has bad threads, don't use it anymore.
Jul 28, 2008 | Olympus EVOLT E-300 Digital Camera
GE A 735
There is a firmware update on our site that will fix that: www.general-imaging.com
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Jun 29, 2008 | GE A730 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
170 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
