Question about Sony Walkman NWZ-S616F MP3 Player
My Walkman won't charge
Well every time I insert the Walkman into the computer or an outlet...A message says LOW BATTERY MUST CHARGE...also the sony Walkman screen logo stays in one place...I have no idea why this is happening
  • 19 more comments
  • akpaws Aug 26, 2008
    Held the reset button for 10 seconds. It seemed to work bur the next day it was the same thing. Now it's not recognized by the computer.
  • music gal Sep 17, 2008
    my walkman won't charge...pressed the reset button but it seems stuck.
  • motznarf Sep 27, 2008
    My walkman will not charge and is not recognized by computer. Tried to refresh and now did a reformat. No luck, help.
  • bbyjenay Oct 10, 2008
    when i try to charge it all it shows is the logo screen. i reseted but it still dont work .
  • recordnow Oct 30, 2008
    Low Battery please charge but will not take a charge
  • almcclure Nov 03, 2008
    Same problem... connected by usb cable to computer but wont charge
  • cybermammy Nov 10, 2008
    same problem! there's also a subtle uh-oh beep noise from pc - it's like it just can't make the connection. Anyone got any solutions??
  • Kaos1107 Nov 24, 2008
    Can't charge my device. It's not recognized by my computer, when I plug it in, nothing happens
  • dmackx_210 Dec 30, 2008
    i plug it up to the computer and it says low battery must charge and the walkman logo just stays there.
  • Anonymous Dec 31, 2008
    when i connect the usb cable to the computer it wont charge and i cant put music into it
  • Anonymous Jan 06, 2009
    Same here,i had lost mine, it worked fine when i last used it, found it again but won't charge, have a feeling the battery is at fault as i've let it go to long without charging it which doesn't do any battery any good.
  • Anonymous Jan 07, 2009
    I plug it into the computer and it won't charge it is really starting to piss me off.
  • CHUY777 Jan 10, 2009
  • Anonymous Jan 12, 2009
  • Wraithmaster Jan 13, 2009
    same problem here i plug the dam thing in it looks like its charging then says full unplug tells me its dead
  • janaymonique Jan 29, 2009
    i cant get it to turn on or get it to charge
  • xwidgywoox Feb 04, 2009
    mine wont charge the screen comes up teling me to charge and the loading bar comes up,loads then doesnt work recognise on my laptop and doesnt charge
  • Anonymous Feb 14, 2009
    When I plug/unplug the player into the computer or the USB charger, the player would light up but it would not charge or be recognized by the computer. I have tried to reset/reformat but it would still not work.
  • joenicholas1 Feb 14, 2009
    my sony will not charge it says low battery please charge and creating library i hit the reset button with no result?
  • alexskater09
    alexskater09 Aug 31, 2012
    what happend when u pres the rest button does it erase everything???
  • Jorge Anthony Vallejo Nov 22, 2012
    My walkman WONT TURN ON NO MATTER WHAT I DO! And Im missing a part on the side of it! PLEEEEEEEEEEEEEEEAAAASE HEEEEEEEEEELLLPPP!
What I did when I got this error was to push the reset button on the bottom of the player itself... Mine rebooted and took a charge from the computer. Hope this all works for you.
Posted on Jan 01, 2009
    Problem Solver:
  • 5 Answers
If none of the above work, try a different USB port. It does not like to connect through a USB hub, and I discovered that the two USB ports in the front of my desktop system simply will not recognize the player. When I plug it into one of the USB ports in the back of my computer, the system recognizes the device and my player charges fine.
Posted on Sep 15, 2009
  • 3 Answers
Hi, I had the same problem. I have an old computer, so I tried it on my daughter's laptop and it started charging. I bought a Music Power dual port USB AC Charger at Walmart for about $15, plugged it into the wall, and it is charging away. I hope this will solve my problem.
I think my computer just wasn't compatible enough to actually charge it. Hope this helps!
Posted on Jan 15, 2009
  • jo6608 Jan 15, 2009
    It charged for several hours, and seems to work fine (for now).
Push the reset button dn't do anyfin put the usb in and it will start to charge it wrks trust me i had da sme problem
Posted on Jul 16, 2009
I had the same problem with not able to charge my Sony Walkman, because it kept saying: FULL when I plugged it in my USB, and when I unplugged it, it said LOW BATTERY.
Eventually I tried everything, and something that did help for me was unplugging all my unnecessary USB products. (I had 2 monitors, printer and etc) After unplugging it all I rebooted, and plugged in my Sony Walkman again, and it started charging!
So it's probably a power source problem.
=D
Posted on Nov 14, 2009
One way to ruin a bettery is to keep running it until it goes completely dead. Digital SONY Walkman devices try to prevent this from happening by not letting you turn it on if the voltage gets below a specified level. One thing that helps is to recharge before they get so low they wont power on. Another trick is to recharge it using a wall charger instead of using the USB cable connected to a laptop. They make wall charger units that any USB cable can plug into, and this only supplies the voltage needed to recharge the unit, but bypasses the step of booting up the Walkman, so in many cases you can just plug the device into the wall and it will charge up fine, then after it gets charged enough to boot okay, you can plug it back into your laptop and sync new music, and let it charge from the computer again. If you cant get it to charge with a wall charger, you may have to go through the process of deleting the Walkman device from Device Manager, Portable Devices in Control Panel, but try the wall charger approach first, that has worked for me in some stubborn cases. Good Luck!
Posted on Nov 09, 2012
  • steven m fisher Nov 09, 2012
    One way to ruin a bettery is to keep running it until it goes completely dead. Digital SONY Walkman devices try to prevent this from happening by not letting you turn it on if the baterry voltage gets below a specified level. One thing that helps is to recharge the battery before they get so low they wont power on the Walkman completely.
    Another trick is to recharge it using a wall charger instead of using a USB cable connected to a laptop. They make wall charger units that any USB cable can plug into, and this only supplies the voltage needed to recharge the unit. When you connect the Walkman to a laptop, the computer assumes it wants to communicate with the Walkman, and tries to boot up the Walkman first before it will charge it. The wall charger bypasses the step of booting up the Walkman, so in many cases you can just plug the device into the wall and it will charge up fine, then after it gets charged enough to boot okay, you can plug it back into your laptop and sync new music, and let it charge from the computer again. I also agree it can help to plug the Walkman cable directly into a USB port on the laptop (i.e. bypass any USB hub, etc. you may have in between), but try the wall charger approach first, it's easy to do, and that has worked for me in some pretty stubborn cases. Good Luck!
If none work, connect the player to the usb port, get yourself a needle and keep pressing the reset button. when it reaches 20% it will charge itself fine.
Posted on Oct 02, 2010
I had the problem everyone else had and got a USB AC charger and it charged up great.
Posted on Jun 09, 2010
2 Suggested Answers
  • 62 Answers
SOURCE: My Walkman is going berserk
when that happens you want to get some thing sharp and hit the reset button on the bottom of the Walkman
Posted on Feb 26, 2009
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
Sep 26, 2011 | Sony Walkman Bean NW-E305 MP3 Player
My sony walkman NWZ-E443 shows power source battery 0.why?
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 02, 2011 | Sony Walkman NWZ-S616F MP3 Player
I have a sony ericsson w995 and for some reason now i cannot charge it, when i try it says 'cannot charge insert sony ericsson battery' but it has one in, i bought a new battery but it still says the...
Had exactly the same problem with my W995. I'm with T mobile. Took it into a T mobile shop and they put it on a PC and updated the software. No more problems. I thought I needed a new battery as I had the same message - "must insert a sony battery." Chap in the shop said its a common software fault on this phone.
Jan 31, 2011 | Sony Ericsson Walkman® W995 Cell Phone
My walkman will not charge. I left it on charge
Hi joanna,
It is probably not turning on due to extremely low battery. Have you been using it for quite a few years? Then there may be a problem with the battery. But before that, please try connecting the player to another USB port on your computer, or removing any USB extensions except what SONY provided, or upgrading your USB driver. If nothing works, I'm afraid you'll have to refer it to a service center.
Oct 22, 2009 | Sony Walkman NWZ-S616F MP3 Player
Nwz-s515 won`t charge
Check for a reset option somewhere in the software, if after reset (or if there is no reset option) it still does not charge then the battery has died. You can call Sony for repairs, it may be under warranty still. If it needs repair head over to Sony's website for repair at:
http://eservice.sony.com/webrma/web/index.do
Jun 25, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
Fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
Jan 31, 2009 | Sony Walkman NWZ-S616F MP3 Player
Sony walkman nwz-s18f froze
I had this problem a few days ago and now my sony nwzs18f has different problems, the way i got it to charge back up was by using a usb charger that plugs into a socket rather than into your computer this should hopfully charge it back up and also it should unfreeze the screen.
hope this helps
Dec 29, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Aug 10, 2008 | Sony Walkman NWZ-S616F MP3 Player
SONY NETWORK WALKMAN NW-E005F
i have a sony nw e305 , same problem no detection and no charging even after it shows tht the battery is charging.. and the walman shows charge error at times...
Mar 30, 2008 | Sony Network Walkman NW-A1200 MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
10,148 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
