Question about Linksys Wireless-G WRT54G Router
Router configuration window
Dear Sir,
I am trying to setup my wi-fi (wireless router) for me to be able to surf the internet wireless.
I have a Linksys Wireless-G Broadband Router 2.4 Ghz model WRT54G version 5.0. I have followed the instructions, but when I get to the part of configuring the router by typing in http://192.168.1.1 in the address bar, I get the window of username and password, I type in both fields admin.
Then I just get a blank screen, it doesn't ask me for instance the SSID, WEP etc.
What did I do wrong ? Please help...
C.L.
    Scholar:
  • 46 Answers
There is not user name for linksys routers. only a password of admin.
if you want a most simplest network installer tool from linksys. On your PC now without the router go to www.linksys.com and look for the Support Button. Click once and scroll down to technical support.
Don't worry, you wont get any idiots here working for this company.
Anyways, scroll down a bit more and click on EasyLink Home Networking Tool link.
This will bring you to a winows to click on Easylink Connect.
Clcik on the link and download the file. Run this file and the setup will do just about 95% or so of all of the work for you. I have use this so any times and never had to restart it because of some problems like the others.
Simple, Simple, Simple. If you should later on upgrade your router to a better one, you use it again to upgrade your network setting to that new router.
Love it, Love it, Love it.
Let me know
comier957
Posted on Aug 10, 2008
Trying to connect my ipad 2 to wi fi via belkin surf n 300 wireless router put password in and message camesup "unable to join the network "Belkin.361B"
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 18, 2011 | Belkin Surf N300 Wireless N Router
I have a laptop dell with vista windows, i want to make it wireless , using my wireless router ,how do it using the model of birght house step bystep. thank you.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then in vista make sure wireless lan driver installed then right clickc on wi fi icon and click on view available wi fi then you can connect it.
Let me know if you need further assistance.
Thanks for using FixYa.
May 05, 2010 | D-Link AirPlus DI-614+ Wireless Router
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
http://1921.168.0.1
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
How do i make my network wireless?
1 - Connect your router to your modem.
2 - Connect your notebook to the router. This is temporary, until you get wi-fi set up in the router.
3 - Start up a web browser, and type in the address 192.168.1.1 - this will access the web setup interface of the unit. Leave the name field blank, and type "admin" for the password (you should change this, once you have it configured).
4 - Setup the internet, etc, and make sure it's working.
5 - Go into wi-fi settings, and create an SSID (essentially, this is what the unit will be called). It probably already says "linksys" in that field. Change it, then create a key (it's a password) for your wireless network.
6 - Save your settings, then disconnect your notebook from the router. Reboot the router.
7 - Make sure you have wi-fi activated on your notebook. Some do this automatically, some don't. It should "see" your network, with the name you gave it during setup. Click on it to connect, and you'll be prompted to enter the password you assigned during setup.
8 - Go surf wirelessly.
Cheers
Nov 04, 2008 | Linksys WRT300N Wireless Router
About wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Feb 10, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
50 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
