Question about Biostar P4M890-M7 Motherboard
MOTHERBOARD I HAVE A BAREBONE KIT WITH THIS BOARD ...WON'T START UP AFTER INSTALLATION ...NO LIGHTS NOTHING EVEN AFTER CHANGING THE POWER SUPPLY ..WHAT MIGHT BE THE PROBLEM?
  • lantipamdkep Aug 23, 2008
    software for
    biostar via p4m89-m7a
  • vincent paya Oct 26, 2008
    same problem but a bit different . i change my motherboard in to this old atx case . after put all stuff in place the front panel switch is not fit my old switch wire is ASKE( says on theplug ) do they have any adapter ? or should i modify it ? oh the sound plug behind DVD rom doesn't fit.
    Problem Solver:
Thanx mullyharley
Posted on Oct 27, 2008
  • 20 Answers
Here a few things to try. Make sure that all connections are correct and snug. Especially the wires coming from the power button etc... Make sure that the memory is correct for that MB and jiggle the DIMMS in the sockets to be sure of positive connection seating. Check to make sure the plug is pluged in (50% of power problems are caused by this so don't laugh). the power supply is properly seated to the MB and the drives are seated solid. Make sure the CPU is correct and alive. The video card and keyboard must be seated and connected properly. Finally, jump out the CMOS and rdplace the battery. If all this fails, contact the MB supplier or the manufacturer itself, explain all the above was done and still no power, and they should replace the board.
Posted on Sep 22, 2008
  • Frank Doll
    Frank Doll Sep 22, 2008
    One final thing, make sure the PS is set to 115 volts not 220.
Asus p5nd motherboard won't start when power button is pushed, but the motherboard light stays on..
Most probably your power supply. An SLI rig will draw a lot of power for the graphics and for a power supply in a system like this to have lasted 5 years is amazing. They don't last forever. You could buy a PSU tester (about 10 GBP) and confirm it. But if you have to buy a new one look for one that is at least 25percent more powerful than your old one and has at least a bronze efficiency rating. (silver would be better) and buy one from a known brand such as Antec, Chillmaster, or OCZ.
Mar 16, 2013 | ASUS P5ND nForce 750i SLI Motherboard...
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
How do test my power supply?
Here is a link to a site that really covers power supplies quite thoroughly.
http://www.motherboards.org/articles/guides/1487_6.html
Sep 29, 2011 | Shuttle SN78SH7 Ultra Barebone Kit ...
Same problem with my D845GVSR
turn off power and reinstall the jumper in normal mode position
Oct 02, 2009 | Intel D845GVSR Motherboard
D845EPT:After the green light of the motherboard is on the system doesn't start.nothing...not even the power supply (I've tested and operates)
Check to make sure you have the board jumpred right with the power on button and reset button (if there is one). Most boards won't start if it is jumpered, even if the leds light up.
Apr 08, 2009 | Intel D845GVSR Motherboard
No Power On Start
Problem Solved, changed the power supply with a 450watt one and it booted fine .
Jan 30, 2009 | PC Chips P25G Motherboard
Aopen barebone XC Cube does not start
Due to the fact that the clock is working on the front panel I would say you at least have some power
1. If your power supply has 110/220 selection on the back make sure that is set to the appropriate
setting.
2. Check to make sure the power is attached to the board right due to you changing the power supply
make sure that the if the board requires the additional 4 pin and or any others from the power supply
that they also are plugged into the mother board!
3. Check to make sure your switches from the power switch/ reset switch / hd lite / etc are all
properly in the right spot and in the right direction observing positive and negative orientation.
If all these are done and still nothing happens and the fan on the power supply is working you still can due further testing on the power supply using a multimeter and checking that the connectors to the board are functioning properly, if they are and you have done all the above things two possibilities remain, one your processor is installed wrong or not working or as you thought, your board could be malfunctioning..
I forgot to mention that you also have to make sure that the fan's are also plugged into the board properly (cpu fan, case fan, etc) this can also disable your computer from starting!
Note: I am going by the information above, if your computer made a sound or anything else please let me know!
Hope this helps
Dec 08, 2008 | Computers & Internet
Power up problem
power supply issue. replace power supply
Jan 08, 2008 | Iwill ZMAX-AP Barebone
MSI K9N6GM MotherBoard Install
you could have a faulty power supply, or something in the motherboard settings could be set to switch the pc off after so many minutes/hours. or you may have a faulty connection which short-circuits in the motherboard or somewhere in the pc, casuing the pc to switch off as a safety feature. this is NOT what it actually is, this is a SUGGESTION.
Nov 28, 2007 | Computers & Internet
Biostar P4M890-M7 Motherboard Logo
196 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
