Question about Refrigerators
REFRIGERATOR TOP SECTION IS NOT COLD AT ALL AND I HAVE ON THE HIGHEST SETTING POSSIBLE..THE BOTTOM FREEZER SEEMS TO BE WORKING JUST FINE BLOWING PLENTY OF COLD AIR. I EVEN CLEANED THE BOTTOM AND BACK GRILLES.
  • CUTLOOSE Sep 01, 2008
    thanks 4 ur help, changed thermostat.fridge seems 2 b working good so far.
  • 725 Answers
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Aug 10, 2008
  • melonie christopher
    melonie christopher Apr 18, 2014
    what does the front kick plate look like?
Maytag side by side refrigerator...freezer fine and fridge gradually went in the danger warm zone. we let freezer thaw for two days. as this has worked in the past. this time fridge has not returned to...
check to make sure the thermostat is not set to the highest level, because all that does is cut-off air flow to the refrigerator.
also you may want to check and make sure the damper motor is functioning. if the damper is stucked in the close position, it will not allow any airflow into refrigerated section.
And lastly, this is a frost free refrigerator, so the fact that you have to let it thaw out lets me know that your defrost system is failing. This will also reduce airflow in the refrigerated section and the freezer will remain cold, not as cold as it should be. So its possible your defrost terminator or heater maybe both has failed. To check this you will need to empty freezer section and remove the back panel at bottom. If you open it up and the evaporator is iced up, then your problem is with the heater or terminator. could be both
Feb 23, 2011 | Refrigerators
My refrigerator wont get cold and it is on the highest temperature possible the freezer is working fine. its still makeing ice but its just that the refrigerator wont get cold. its also 10 years old.
Always set the controls to their "normal" recommended setting. Changing them will not work. Is there air blowing from the freezer? The freezer fan may not be working. Or if it is, possibly the air flapper could be stuck closed not letting air flow into the refrigerator.
Dec 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Jun 24, 2009 | LG LRTP1231W Top Freezer Refrigerator
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
