Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Samsung 913v monitor
I signed up with a person called moseslive on the 21st July and after exhausting all other avenues decided I need to download a driver. However I was at work trying the monitor on my work computer and I did not have the internet connected at home. Mow I have the internet and can download the driver I can't find the site. Can you please help.
regards
Julie
    Scholar:
  • 36 Answers
Here it is
http://www.samsung.com/it/function/search/resultList.do?searchWord=913v&ct=0&sort=0
Posted on Apr 14, 2009
SOURCE:
I have signs such as lines forming a nest on the monitor
These are dead pixels which is a common thing in LCD monitors. Basically these pixels stop giving out light, or incorrect light and they are useless. You need to get a new monitor if you can't live with them.
Have fun :)
Aug 14, 2011 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung lcd television the screen goes blank after 20 mins of watching there is still sound though
right click on your desktop.go to properties.then go to the screen saver tab.click on screen saver tab.then you will see call monitor power.click on the power icon.go to the settings forr home/office desk power scheme.there you will see a setting called (turn off monitor)change that.let me know if it did work hay.
Sep 07, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Apr 20, 2009 | Samsung SyncMaster 720N Monitor
Samsung 913V LCD Monitor--No display when vga plug plugged in
1. please check by pressing num lock or caps lock key to verify that your machine is booting up, if yes then check the cable and if after changing the display cable it doesnt show up anything, it means you have a faulty unit
2. if numlock/caps lock key doesnt work, then your machine is not booting up, please check for loose ram etc.
Apr 04, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
thank you
Feb 24, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913v Monitor
if there are too many black spots already then that means there are lots of dead pixels on your lcd and it cannot be repaired anymore. that will continue to add more dead pixels and eventually damage the device.
Aug 24, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor syncMaster 913v wont run 1280 1040 Resolution has in past goes blank moving "box- message' says ajust to 1280 1040 resolution Runs on other resolution settings ok
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor to the nearest samsung's service center.
Best regards
Jan 08, 2008 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 710N 17 in. Flat
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
171 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
