Question about Gateway Computers & Internet
Keep getting the theft deterrence box popping up and screen going to black and white
  • Gateway Master
  • 3,051 Answers
You will need to boot the computer into the bios and once there go to the secutity section and look for somthing refering to the theft deterent device and disable it it also might have a line reading if the case has been opened i generly will disable this too then save settings and exit and restart the computer please let me know how this turns out best regards mike
Posted on Aug 10, 2008
SOURCE:
Need to know where the tdm is on a 1997 Cadillac deville can't get security system to shut off should I replace ecm ? Please help
It's hard to get the SECURITY light to go off when you don't know how it works ! Replacing the PCM could cause you more problems too . If a replacement PCM is being installed it must be programmed (flashed) using the latest Techline programming procedures.
Having the vehicle check for DTC ' S - diagnostic trouble codes would be the first step.
DTC P1626 Theft Deterrent Fuel Enable Signal Lost
DTC P1630 Theft Deterrent Learn Mode Active
DTC P1631 Theft Deterrent Start Enable Signal Not Correct
DTC P1632 Theft Deterrent Fuel Disable Signal Received
This anti-theft system does not use a TDM - theft deterrent module . The instrument cluster is the controlling module . Look at a wiring diagram here
http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model engine . Then under systems click on body & accessories , then in subsystem click on security / anti-theft . Click the search button , then on the blue link .You mite be able to do a by-pass if the contacts inside the key lock cylinder is the problem . You can check it with ohm meter . The key has a resistor pellet on the side , you can check the value with ohm meter , find the two wires under the dash at the steering column . Two white wires inside a yellow or orange sheathing . There are videos on youtube !
Apr 13, 2017 | Cadillac Cars & Trucks
How am i supposed to get ride off the Service theft system?
It's hard to fix something if you don't know how it works ! Fixed ignition ? What did you fix or change ?
SERVICE THEFT SYSTEM
Security: Refer to Theft Systems Description and Operation in Theft Deterrent
You need to have it checked for trouble codes .
The theft deterrent system on this vehicle is comprised of two separate systems, the vehicle theft deterrent (VTD) system and the content theft deterrent (CTD) system. The VTD system prevents drive away theft by keeping the vehicle from starting. The CTD system is the vehicle alarm system which discourages unauthorized entry into the vehicle. These systems are described and diagnosed separately within this section.
Theft System Indicators
SECURITY The instrument panel cluster (IPC) illuminates the SECURITY indicator as determined by the vehicle theft deterrent (VTD) system and the content theft deterrent (CTD) system. The IPC receives a message from the theft deterrent control module or the rear integration module (RIM) via the serial data circuit requesting illumination.
The VTD system requests the IPC to illuminate the indicator only when the ignition switch is ON. The VTD system uses the indicator as a malfunction indicator. For specific VTD condition that will illuminate the security indicator, refer to
Vehicle Theft Deterrent (VTD) Description and Operation .
The CTD system requests the IPC to illuminate the indicator only when the ignition switch is OFF. The CTD system uses the indicator in order to identify system status. For specific CTD condition that will illuminate the security indicator, refer to Content Theft Deterrent (CTD) Description and Operation .
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
SERVICE THEFT SYSTEM The radio illuminates the SERVICE THEFT SYSTEM message when the VTD system detects a failure. The radio receives a message from the theft deterrent control module via the serial data circuit requesting illumination.
This is one you need to take to the dealer , unless you have a GM factory scan tool !
Nov 21, 2015 | 2004 Cadillac CTS
I need to get passed the anti theft reset to get my 2000 cad.devlle.going, just bought it, I need help to locate fuse boxes, would like to trade somebody for a sharp running truck or car straight across,...
One is under the hood in the engine compartment an Rear Fuse Block
Left rear of the passenger compartment, under the rear seat ! There are a couple of fuse's , but they power up the ignition an the PCM ,so you can't pull those ! Beside that if the PCM does not get a fuel enable signal from the anti-theft module the vehicle won't start . You can't just disable thing's on this vehicle ! If you have security light on steady or flashing you need to take it to someone who has a diagnostic scan tool that can check DTC'S - diagnostic trouble codes ! A code reader can not access these type codes !
Vehicle Theft Deterrent (VTD)Circuit Description
(VTD) Theft Deterrent System Components
Ignition Key (Transponder) The ignition key for the (VTD) theft deterrent system is a typical ignition key with a transponder pellet located in the plastic end of the key. The ignition key transponder value is used to determine if a valid ignition key is being used to start the vehicle, there are approximately three trillion different transponder values available. This vehicle has two types of ignition keys.
Master key (black plastic end) which can start the vehicle and lock/unlock all door locks, all storage compartments and the rear compartment lid lock.
Valet key (gray plastic end) which can start the vehicle and unlock/lock all doors, but can not unlock/lock the storage compartments, or rear compartment lid lock.
Important: The transponder values are not readable and can not be serviced separately.
Theft Deterrent Module The theft deterrent module contains the software for controlling the VTD System. The theft deterrent module uses the following inputs and outputs to control the VTD system.
Inputs ?€¢
Battery voltage from the underhood fuse block PCM/BATT fuse, circuit 240 (ORN).
Ignition start voltage from the ignition switch, circuit 1390 (WHT).
Ground, circuit 450 (BLK).
Outputs Password exchange with the PCM (fuel enable), class 2 message circuit 1807 (PPL).
Powertrain Control Module (PCM) The PCM verifies that the passwords received from the theft deterrent module via the class 2 serial data line are valid. If a password is invalid the PCM disables the fuel delivery system. If the password is valid the PCM enables the fuel delivery system.
Starter Relay The starter relay is controlled by the PCM module via class 2 serial data (CKT 1807 PPL). If the theft deterrent module measures the correct transponder value, the PCM module switches the starter enable control (CKT 447 YEL) to ground. The relay is energized if the ignition switch is in the START position and the gear selector is in the PARK or NEUTRAL positions.
Mar 24, 2015 | Cars & Trucks
2007 gmc acadia - Why is there no power to the theft deterrent module / anti theft module located at ignition?
Brown wire is not for data , for ign. voltage . in run or acc. Red white wire gets it's B+ voltage from PWR MOD fuse 2 amp. I/P fuse box . Having the system check for DTC'S diagnostic trouble codes is the first step in diagnosing a no start .
DTC B3006
DTC B302A
DTC B3031
DTC B3055
DTC B3060
DTC B3935
DTC B3976
DTC P0513
DTC P0633
DTC P1631
Diagnostic Starting Point - Immobilizer
Begin the system diagnosis with the Diagnostic System Check - Vehicle. The Diagnostic System Check will provide the following information:
• The identification of the control modules which command the system
• The ability of the control modules to communicate through the serial data circuit
• The identification of any stored diagnostic trouble codes (DTCs) and their status
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
There should be a dark green wire also ,at the theft module . This is for data communications , low speed GMLAN . Do you know what GMLAN is ? GM's version of C.A.N - controller area network . If your missing this wire , no wounder it won't start .
Theft Deterrent Control Module Pin
Wire
Circuit No.
Function
0.35 RD/WH
1040
Battery Positive Voltage
0.35 BN
Ignition I/II Voltage
0.35 BK/WH
1551
Ground
Not Used
5
0.35 D-GN
5060
Low Speed GMLAN Serial Data
Your best bet ,take it to the GMC dealer , there is no way to by pass this .
Aug 19, 2017 | 2007 GMC Acadia SLE
Not sure.Go to my.cardone.com It has GM Vehicle Thief Deterrent instructions,I hope you find the solution.
May 11, 2014 | 2007 GMC Acadia SLE
Anti thief device
Check the help links mentioned below :---Relearn Theft deterrent module? http://technoanswers.blogspot.com/2012/01/relearn-theft-deterrent-module.html
---------theft deterrent module Relearning? http://howtobyme.blogspot.com/2012/01/buick-theft-deterrent-module-relearning.html
--------Engine will not crank after relearning Theft deterrent module? http://howtobyme.blogspot.com/2012/01/engine-will-not-crank-after-relearning.html
--------Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
Car Factory Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
---------Car will not start security lock out? http://technoanswers.blogspot.com/2011/12/car-will-not-start-security-lock-out.html
---------Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
--------This will help.For more info keep updated.Thanks.
Feb 09, 2012 | 1998 Plymouth Voyager
My 1993 Toyota Tercel does not start when key is turned. New battery, all fuses checked and fine. When the doors get opened, hazard lights start blinking for 15 blinks, then pause, then 15 blinks. This...
This sounds like a starter disable feature of a car alarm. Somewhere under the dash you are going to find a box with the start wires running to it. The start wire is black with a white stripe and is thick, about a 12 gauge wire. It will come from the ignition switch and run into a relay or box. It could be installed anywhere as it is aftermarket. Once you find it, you can reconnect both ends of the starter wire and you can start it with the key. I would disconnect the power to the alarm or your lights are going to flash at random. The factory alarm (just in case it is the issue, but that isn't likely) is located behind the radio and ashtray.
Dec 14, 2010 | Toyota Tercel Cars & Trucks
Power went off and now my gateway monitor displays GatewayWhield theft Deterrence. I never set up a password how do I fix this problem. Connect the monitor to the pc you would think fixes it but no. Help
Disable GatewayShield Theft Deterrence
  1. Launch EzTune.
    View Picture
  2. In the EzTune window, click the Plug-ins tab, and then click Theft Deterrence.
    View Picture
  3. To deactivate theft deterrence, click Disable Theft.
    View Picture
  4. Type the PIN for the monitor in the appropriate field, and then click Accept.
    View Picture
  5. A screen confirms that theft deterrence is now disabled.
    View Picture
Dec 03, 2010 | Gateway FPD1785 Monitor
Theft disable menu pops up and won't go away and it keeps turning off my monitor
You need to install EZTUNE from Gateway, but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
User manual:
http://www.retrevo.com/support/Gateway-FPD1975W-Monitors-manual/id/1071ag416/t/2/
Apr 14, 2010 | Gateway FPD1975W 19" LCD Monitor
Theft Deterrance system
If you ever have this problem but cannot get to the 'extras' button, leave the computer on that (hopefully) already has the eztune software installed, pull the power on the monitor (the cord, not just press the power button) and then plug it back it...it should unlock automatically. It ticks me off that I just got off the phone with gateway tech support and they wouldnt tell me that because my monitor is 'out of warranty'...purchased 4/8/08 and problem today 7/15/09...bums. Anyway, they offered to fix for a fee. I got it fixed.
Sep 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Computers & Internet Logo
110 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
