Question about Avanti W798SS Stainless Steel
Faucet Adapter included doesn't fit my faucet
To Whom It May Concern:
Can someone please help me locate a faucet adapter that will fit my faucet? The adapters included with the Avanti W798SS do not fit my faucet. Looks like they fit standard faucets only. My faucet has threads on the outside of the faucet and the faucet spout is 2mm in diameter. I checked Home Depot and their people are no help at all.
I thank you and appreciate your time.
  • 332 Answers
Avanti is on a metric system and depending on where you are you might not be on metric thats why they don't fit,, one has a fine thread the other is course, you will need ot go to an actual plumbing supply house, they have the converson fittings,, don't waste your time at home depot
Posted on Jun 23, 2009
  • 129 Answers
I to have had trouble getting help at home depot, I'm sure if you try Lowes they will be very helpful. Tell them you need an areator with threads on the inside to fit your spout.
Posted on Sep 18, 2009
  • 91 Answers
The adaptors are out there. Home Depot does not usual have the most helpful staff. Try a Maclendons if there is one near you. You can find the adaptor through online plumbing supply sites. Even www.hdsupplysolutions.com
Posted on Aug 27, 2009
2 Suggested Answers
  • 10865 Answers
SOURCE: I can't find an adapter for my kitchen sink that
Hi. Take the hose to most any neighborhood hardware store and they will fit it for you. Often, a local mom and pop hardware will be most helpful and knowledgeable. I assure you that there is a fix for your problem. J.
Posted on Jul 31, 2010
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
Washing machine flashes and beeps E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Frigidaire Washing Machines
Error code #E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.Hope this helps... Please post back for more information.
Daniel
Nov 16, 2010 | Kenmore 43142 Front Load Washer
On my wslp1100 model its very very hard to connect the hose to the faucet adapter, it just does not want to go in ,also it leak's a lot of water from where the hose connects to adapter , I have to wrap a...
Hi... I had the same problem. Instead of trying to figure out the faucet/adapter issue (was too pissed off) :) I took my old washer hose and just used that. Connect the washer hose to your sink and the washer just like it would be if you used that adapter hose. You will want to make sure it is tighten good or it will leak a little...and make sure that the adapter hose end is in your sink because that is where the used water empties out from.
Hope this helps.
Aug 06, 2010 | GE Spacemaker WSLP1100D Top Load Washer
I have Malber WD1000. Hot water run through the pipe, but do not fill machine. How can I find and check the filter of hot water in machine
Hello. Just turn off the water and then remove the fill hose which goes from the water faucet into the back of the machine. Examine the entire hose and pay closest attention to the filter located at the end of the hose nearest the faucet. regards, Joe
PS - please rate my answer as helpful Thank you.
Feb 08, 2010 | Malber WD1000 Front Load Washer/Dryer
Parts to hook to sink faucet
You have to remove the strainer from tap faucet, adapters for different threads at hardware store
Aug 02, 2009 | Washing Machines
LG WM2010CW filter drain no draining
In all likelihood the rubber drain hose is clogged. I had the same problem with my LG front loader. The hose was clogged with sand and dirt almost the entire length of the hose. The following solution is far simpler than taking the dryer apart to clear the drain hose. Besides I figure this same thing could keep reoccurring with all the sand and dirt we get in our clothes here in East Texas.
I purchased about 4 feet of 3/16 inch OD vinyl tubing and adapted it to fit on the end of a garden hose. The adapter gizmo included a valve so I could control the water flow and not give myself a bath. A picture of the gizmo is included below. Make sure that when you connect the water hose to the faucet that the faucet valve is just slightly opened and that the gizmo valve is closed. Using the gizmo is straight forward. First remove the drain filter and than insert the vinyl tubing in the end of the rubber drain hose and slowly open the valve on the gizmo. Make sure you have a large pan or bucket underneath the drain hose to catch the debris and water. Slowly advance the tubing up inside the hose until it won’t go any further. By this time water will also be running out of the drain filter cavity which will indicate the clog has been removed. Continue back flushing for a few more seconds to assure all the debris has been cleared, than clean up and you’re finished.
May 11, 2009 | LG Washing Machines
Popping while removing Hose Adapter
Are you sure the adapters are installed in the correct direction? To release the pressure you could turn the water off, and then turn the washer on. The residual pressure will be released. Then you can turn the washer off and remove the hoses.
May 06, 2009 | Haier HLP21E Top Load Washer
Faucet adapter
home depot. that's where i got mine. i paid almost $9.
Jan 13, 2008 | Haier HLP21E Top Load Washer
Avanti W798SS Stainless Steel Logo
615 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
venugopal durairajan
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
