Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
No picture at all
I just upgraded my system board to the ecs elitegroup geforce6100sm-m2 and i get no picture either from pluging cord into the motherboard or the new pci express video card... i'm at a loss, don't know what the problem is.. what can i do to troubleshoot and fix..??
  • jrl1261 Aug 26, 2008
    I'm having the same problem with the GeForce6199PM-M2. Just bought it last weekend. Can someone please help me?
  • Anonymous Sep 28, 2008
    if i cant see anything on the screen how do i get in to the bios
    President:
  • 2,351 Answers
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Mike
Posted on Sep 25, 2008
  • Mike Peluso
    Mike Peluso Oct 03, 2008
    Hi geminip3, How to get display? First, if you have a PCIe connected to the board remove it. Than while your inside the system clear your cmos/bios. Open your manual to page 4. See number 8 for location on the motherboard. See page 9. Move the jumper from pins 1 & 2 & set to pins 2 & 3. Count to 15 & move the jumper back to pins 1 & 2. Connect your monitor to the VGA output connector on the back side of the motherboard. By clearing the bios it will automatically revert to the onboard video. Boot your systems & check for video display. If you do not have display even though the system seems to be loading. Check your monitor by connecting it to another working system or notebook. Check all internal connection. Make sure nothing is loose. Still no display? The board may be faulty.
    ECS tech said in an email; There are no changes that need to be made to use a PCIe video card. The BIOS will automatically disable the onboard video once it detects a working dedicated video card. The board may be defective. Call ECS (See your manual for number) or e-mail ECS. Start here;
    http://www.ecs.com.tw/ECSWorldWide/Index...
How to plug your usb control wire into *********** board
it will say usb on motherboard the spot that dose not a wire goes to that spot only one way
Mar 03, 2014 | EliteGroup ECS GeForce6100SM-M (1.0)...
I have just formatted my pc with the GeForce6100SM-M2 motherboard due to a virus. I installed the drivers but for some reason i cannot set up a network to access the internet. The wizard gives me a screen...
Yes, the yellow mark is a missing driver of the wifi adapter. you have to get the updated driver on
http://download.driverguide.com/driver/GeForce6100SM-M2/ECS+Elitegroup/d1551425.html
Mar 27, 2011 | Computers & Internet
I have put a "GB DDR2 -800 in each memory slot in
because there is a defect with the dimm slot 2 on these mobos.I have the same problem.contact ecs therell give you a bios update but it wont work
Nov 09, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
I have a P4M900T-M2 mobo, and I would like to buy an Intel Q8400 (2.66G) 4mb 1333fsb. But P4M900T-M2 mobo says.. -> FSB 1066/800/533 MHz and an Intel Q8400 has FSB 1333Mhz Will the two of...
No, the one you want will not work simply because it's too powerful for the board and will not be recognized. Here you can find all supported processors
http://www.cpu-upgrade.com/mb-ECS/P4M900T-M2(V1.0).html
as you can see the only ones for your mobo are Q6600 and Q6700.
Aug 08, 2010 | EliteGroup ECS P4M900T-M2 Socket 775...
Connection of power button
Hello it should be this picture:
The mainboard home page is here:
http://support.gateway.com/s//MOTHERBD/Shared/4006233R/4006233Rnv.shtml
Good luck
May 16, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
I try to connect my ECS Motherboard one again but
you may have misplaced the power switch connections which come from front pane to the mother board
there are many of them like pwr switch, reset switch
hdd led etc
check *********** board it will be indicated where to connect the pwr switch pwr led etc
May 07, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
I CAN NOT DOWNLOAD THE DRIVER FOR ECS P4M900T-M2 SOCKET 775 MOTHERBOARD. CAN YOU HELP ME?
Try EliteGroup support for your product: (under Downloads, click on Driver - choose the correct driver for your operating system)
EliteGroup P4M900T-M2
Dec 30, 2009 | EliteGroup ECS P4M900T-M2 Socket 775...
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
616 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
