Question about Singer Sewing Machines
Thread tangled - old singer sewing machine(1947, AG)
I acquired the old singer sewing machine(1947?, AG), but I don't have a manual. It worked fine for a short while. Then, one day, the upper thread got caught (in the case which the bobbin case is in) as soon as I started to sew. I'm not sure where I touched - trying to change the tension, etc. So, I cleaned, re-threaded, put oil on it, etc. I tried to do whatever I could think of to fix the machine though, It haven't been fixed yet. I would appreciate if anyone could give me any advice. Thank you.
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
dupina
  • 110 Answers
SOURCE: singer solid state-bobbin part
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Also use a ball-point needle on t shirt material. Good luck!
Posted on Nov 03, 2008
  • 4 Answers
SOURCE: Birdsnest and machine jams
I have a singer 457 (from 1964!!) that I inherited from my grandmother. It worked successfully many months, but then I developed a similar problem (birds nests, tangles in the bobbin assembly).
AFter messing with the tension, different spools of thread, and what not, I found that it was the BOBBIN that was the problem. Althought this bobbin is the same size and shape as others, there is something about it that knots up the inside of the machine EVERY time (as in within 15 stitches or less).
I tossed the thing and have been trouble free ever since.
I am now convinced that bobbins (particularily plastic ones) wear out.
Posted on Jan 27, 2009
  • 69 Answers
SOURCE: How do you adjust the bobbin tension on a Singer
With your slide plate open, you will see 2 screws on the bobbin case. You need to adjust the one on the inside (not the one that sits at the edge of the metal strip). Do so very slightly. If you can't seem to get it adjusted, take a look and make sure there isn't any thread or lint in between the two pieces of metal that the thread feeds through. This can cause a loose tension.
Posted on Mar 01, 2009
Error code c4
try these suggestions
try changing the needle
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help then the machine needs to be checked
Oct 06, 2012 | Singer 7258 Sewing Machine
Singer 5040c i just bought this machine it was working fine but i thought i should clean it after cleaning all of a sudden the bottom thread is looping up all over and the tension is not right. When I...
Do you have your manual? Because it is almost always the top threading, either tangled thread or a bent or dull needle causing the problem. You can download your manual at www.singerco.com for free and enlarge the detail of the diagrams for threading. I just hope that it is something simple and not your timing because that is not a do it yourself job, unfortunately. You can also call Singer customer service at 1-800-4singer. and get their advice. Good luck.
Oct 11, 2010 | Singer 5050 Mechanical Sewing Machine
I have a singer touch and sew and the bobbin keeps knotting up when i sew. what could be the problem/
You may have tangled thread or the bobbin not threaded right. Totally rethread your machine according to your manual. If, you do not have your manual handy, download one for free at singerco.com. Good luck
Sep 12, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
14SH654: Singer 247 Machine runs fine and then bottom bobbi...
Try using a style 60 or 66 bobbin. I had the same problem at first, and someone on-line suggested the different bobbin. I use a style 66; instead of having a flat bottom and top (and all those holes), it's shaped something like a bagel. Now my machine works beautifully.
May 16, 2010 | Singer 14SH654
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
On my old Singer 834, the bobbin thread puts out
Are you sure the bobbin thread is in the case correct. it also as tension support.Or is the bobbin thread right . When you make your bobbins that also should have tension.
Aug 15, 2009 | Singer Sewing Machines
Thread tangles around shuttle
are u talking about 3-4 uses from being a new machine or is this a machine you aquired,,,,alot of times the machine can be off timing, if this is not the case always try fully unthreading and rethreading and please use rayon or polyester thread, plus make sure you have the bobbin case in correctly
Jan 20, 2008 | Singer 3116 Simple
Sewing Machines Logo
176 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
