Question about Kenmore Oasis HE 27082 Top Load Washer
Don't start the machine don'start I push the stop botton an the panel go on but went push the start botton everiting turn off
  • cudaboy72200 Aug 28, 2008
    Mine will not come on at all.. help
    Genius:
  • 1,142 Answers
It doesn't work at all If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Aug 10, 2008
My 2nd machine and same problem the start botton falls into the machine its a push botton 2months out off gareintee
you can remove the panel and look inside, the button is usually spring loaded. and u may be able to work with it to fix it? many times a build up of soap and softner can cause sticking keys
Mar 26, 2015 | Washing Machines
Problem with ac window unit panel and remote will not work,pushed all bottons to work and just wont.Could it be the mother load panel?
Sounds like a control computer board problem. Some times unplugging and leaving it for about 30 seconds and plugging it back in can recover from the fault.
Jun 29, 2014 | Crosley CAE15ESR 15,000 BTU Window Air...
I don't how to set the timer. please help.
keep central heat off (botton on left push down botton on right push all the way up. Turn dialclock wise and either push in the little white button or pull out the "advencor". that button works the speed of the dial by turning it also
Mar 11, 2013 | Heating & Cooling
Sansui lcd 32 inch will not turn on
the picture tube thing could have went out
Jul 16, 2012 | Sansui HDLCD3210 32 in. LCD TV
DE PUSH POWER BUTTON POWER COMES ON GOES RIGHT BACK OFF, IF YOU HOLD POWER BOTTON IN AND TURN KNOB TO A CYCLE THEN PUSH START BOTTON ERROR dE COMES UP
Check the outlet first. If the outlet is ok, then you have a control board issue. Replace the control board. Good luck.
Jun 19, 2011 | LG WM2487H Front Load Washer
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool kenmore ultra wash diswasher
Hi jimills13,
I'm Harvey the Master Plumber.
Your question is: Stopped with water in the basin... will not respond to any bottons being pushed tried diagnostic button dance ...nothing Checked power to the machine= good what is the next step. replace parts?
Gosh no. 9 times out of 10 the problem is loose, brocken or burnt wire connetion in d/w junction box. Turn off power to unit. Remove bottom kick plate. On right you'll find box held on with one screw. Remove and take apart wire nuts. Replace/repair as nessessary. Turn power on and test d/w before replacing box and plate(you may have more to do). Be carefull!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Dishwashers
Kenmore Oasis HE 27082 Top Load Washer Logo
71 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
