Question about Carrier 38CKC036 Air Conditioner
Blank Thermastat LCD
I have a Carrier Model 38cks
Split air and the thermastat lcd has gone blank
  • PumpkinDog Mar 01, 2009
    My Carrier thermostat LCD goes blank (for carrier heater/AC wathermaker 9200). If i open and shut it it comes back on for about 10 minutes and then shuts off again.
  • 182 Answers
Check power to the furnace.
Posted on Aug 10, 2008
How do I get the battery out of the thermastat?
There is often a band under the battery that can be pulled to lift it. The band may not have been placed so that you can.
A pointed object might be used to push in at the NON-SPRING end of the cell and lift it out.
If those fail, try tapping it upside down to shake it loose.
Sep 01, 2014 | Honeywell Heating & Cooling
Thermastat display is blank
have you replaced the batteries in the thermostat? some didital thermostats have batteries and wont work when they are bad
May 07, 2012 | Heating & Cooling
LG Optimus blank screen
This sounds to me like the LCD Backlight has gone bad. You will need to get in contact with your carrier to inquire about warranty service or replacement.
Apr 10, 2012 | LG Optimus Black Smartphone
Commercial 5 ton carrier heat pump will not turn off when thermastat is off have to take it off the wall to stop
If taking it off of the wall stops it then the t-stat relay has gone bad and is siezed together...
You will need to replace the t-stat... make sure tomark all the wires and turn off all power to the unit before replacing..
heatman101
Thermostat Wiring and Terminal Designations
Dec 13, 2010 | Goodman CLJ30AR32 Air Conditioner
When the thermastat turns on the furnace doesn't ignite the burners and the pilot light is lit. Everything appears to be normal, fan runs, thermastat appears to work properly.
You may have an open limit or a bad gas valve. Check and see if you get 24 volts to the gas valve, if you do then you gas valve has gone out.
Oct 06, 2010 | Heating & Cooling
Carrier AC Model No. 38CKS fan not spinning
You have bad cccccccccapacitor in your outside unit. Not hard to replace but you need to find someone to sell you one It should say 45 5 or 50 5 on the side of the capacitor. You can also call a service tech about 150 for the repair. Rus Carrier Dealer 45 years
Jul 18, 2009 | Heating & Cooling
My Sony Hc42 camera LCD, view finder gone blank
cheak ur lcd srip and there is a samll switch that chaing over switch cheak it
Jul 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Blank thermastat
Check for a blown fuse inside the air handler.
Oct 13, 2008 | Carrier 38CKC036 Air Conditioner
Ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Aug 31, 2008 | Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
155 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
