Question about Sharp Computers & Internet
I have a sharp aquos hd tv/monitor with rgb and hdmi cable inputs.How do i know if it is compatible with any given pc processor?
  • 36 Answers
Depends on the Computer. Some have a 15 pin on-board video - in which you can buy a 15 pin to HDMI adapter. Others have video cards with DVI outputs - in which you can buy a DVI to HDMI adapter. Or you can buy a video card to supoorts an HDMI output.
Posted on Aug 10, 2008
How can I get the best HD (cable) signal to my old HD TV with no HDMI port. The TV only has Component Video, S-Video, RGB input, and of course Coax input. The TV is an LG DLP TV.
If it is an hd compatible tv the is has to have either an hdmi port or a dvi port. Our old projection tv was hd but before the current hdmi format so we had to use an hdmi to dvi conversion cable. If it doesn't have either of these then it probably isn't hd compatible.
Nov 15, 2017 | LG Televison & Video
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
Hello
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
I can't play movies on my tv
Okay, this monitor setup is a little strange. There is an "AVC" component with this monitor that you use to connect everything. There is a 4 cable string (power, s-video, DVI, display port) that connects the AVC unit to the monitor. You must have all external equipment connected to the AVC unit, not to the TV itself. The connections on the TV talk to the AVC unit. I will assume you will be connecting the Blu-ray player via HDMI. HDMI is on input 4 on the back of the AVC unit. hit the input button on the remote or the TV and select input 4. There is a way of customizing the inputs to read out what you have connected to them (ex. DVD, VHS, etc.) to make it easier to use. This should get you signal from your blu-ray
Nov 06, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to use a sharp aquos as a monitor with my laptop
Hi. You haven't said how you have connected your laptop to your TV so I'll give you a couple of options:
1. VGA to VGA (This cable is a 15-pin cable like the one you would use to connect a computer monitor to the back of the computer box itself). The Sharp has a VGA connection at the back.
2. DVI to HDMI. If your computer has a DVI output, this would be the best connection.
On your remote, press menu.
Use the left/right arrows to select option
Then use the arrow up and down to select input source.
Depending on the TV you have, you will either see the actual name of the connection (ie. HDMI, DVI, VGA) or you may need to select Input 1, Input 2, etc... depending on which connection you used. The input number may be labelled on the back of your TV.
If none of this works, please let me know your model numbers and I can provide you with instructions specific to your models.
Jan 19, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Computers & Internet Logo
391 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
