Question about AT&T 2256 Cordless Phone
Key pad not operating well.
All the keys are hard to push and many require 6 or 7 touches before it responds.
  • 79 Answers
Something such as coffee or soda may have been spilled in the phone causing a loss of connectivity between the keypad and the contacts. The keypad is a rubber membrane with soft round nubs on the bottom that press against gold circuit board contacts when depressed. It would have to be disassembled and clean with q-tips and rubbing alcohol or similar solution. This is for a professional or handy person to perform only
Posted on Aug 23, 2008
It wont respond to any key pads i push. Just says welcome to panasonic oven cooking.
try to unplug unit then press clock or number pads to set clock first then try to use. if wont work, maybe bad touch pad or controller
Mar 23, 2018 | Panasonic Microwave Ovens
When get to my home screen my cursor wont move when I move my finger on the mouse pad.
I'm assuming that you are using a laptop. If so, then look around for a button that locks out your touch pad from being recognized. Some laptops have the Touch pad "On\Off" button just above the touch pad. Other laptops will require you to do a key-combination to turn the touch pad On or Off. To do this typically requires you to press the FN or Function key while pressing one of the keys between F1 - F12. There should be a symbol\icon of a different color on whichever key it is that will give you an idea of what that key's function is. Every laptop is setup and arrange slightly different.
Aug 17, 2010 | Computers & Internet
I have a Kenmore Double Oven that's eiving a Code 7 and beeping
Hello,this code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks
Jun 02, 2010 | Kenmore 43389 Electric Double Oven
Kenmore model 911 4238816 - the f7 code just came on beeping and we can't get it to stop. what is the error code mean, what can we do to stop it
HI. This code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
Jan 03, 2010 | Kenmore Ovens
Oven blinking code F7?
Determine if problem is with the Key Panel or Control by:
Dec 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Buttons are hard to push, always gives me a
Hi, no need to trash this unit. you can repair this and, its quite easy. the touch pad(key pad) is faulty and, you can purchase the replacement pad, via the link provided below. the instruction will be shipped with the part if you order it from the site. you will need to remove the units cover and, the control panel will be exposed. just replace the bad with the new.
Click here to purchase a new Touch key pay.
Jun 18, 2009 | Sanyo EM-N107 600 Watts Microwave Oven
Toshiba Laptop "Enter" and touch pad not working
This screen should have a 30 second count down, then start Windows normally. If yours doesn't do this, then she may have keyed the automated recovery and interrupter it causing an operating system error or glitch. If this is the case you will need to run a system repair with your recovery or operating system disc. If it does start Windows after the count down, then run a system restore. One of these will take care of your problem. Also, there is no locking command for the touch pad or enter key.
Aug 01, 2008 | Computers & Internet
Lg key pad not working
ur key pad domy is damaged so change it quickly
Feb 14, 2008 | LG KG800 Cellular Phone
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
AT&T 2256 Cordless Phone Logo
271 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
