Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Dishwasher fuse LG LDS5811
Hi Ginko, I found the fuse, but it seems to be glued in. How do you remove it? I don't see that in the manual.
  • pacificcoast Aug 10, 2008
    I think I just attached a picture of the fuse. Did you get it?
  • LG Master
  • 19,396 Answers
You need to test the fuse for continuity using a multimeter tester, if the multimeter returns infinite impedance then fuse is blown and must be replaced, the fuse is not normally glued, but after a short some contact may have melt down and now fuse is soldered. If this is the case, fuse must be unsoldered and replaced.
See if you can publish here a picture of fuse.
Posted on Aug 10, 2008
When the LG dishwasher come on it try to start then le flashes and it dost start what do i do
You have a water fill problem.
Make sure the water supply is turned on.
Could be a bad water valve,bad wire bad timer,etc.
Copy and paste this Factory Service manual to help in diagnosis.
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
It may not be specific to your model number,you did not post a model number.
It should help generically.
Sep 14, 2010 | LG Dishwashers
My dishwasher is showing LE on the display and will run but doesn't seem to be cleaning the dishes. Any solutions?
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
(Just copy and past the above link in your web browser)
Good Luck!!
Thanks
Mar 27, 2010 | LG 24" Built-In Dishwasher - Black
LE error message
Good Luck!!
Dec 11, 2009 | LG Dishwashers
Heater not working in cycle. No Error Code present
The LG 5811 dishwasher would display the error "tE" if the thermistor has failed. Not seeing an error could mean that the controller card (PCB) has failed. Hard to tell if the heating element has failed or wiring has shorted.
To look a little further, you can see (but not remove) the heating element by removing the filter in the sump area beneath the bottom rack. Disconnect dishwasher from power first and inspect for obvious failure of element.
Gaining access to the heating element is very complicated on the LG units. You have to drop the entire sump unit after turning the dishwasher over on its top.
Recommend a service call.
Feb 10, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code LE shown on a LG dishwasher model LDS5811ST and this code is not given on the standard error code list.
Hello JA12345,
Here is a link to the service manual for your dishwasher. Page 25 discusses the error code...
Hope that helps you resolve your problem..
Regards,
Rick
Dec 13, 2008 | LG Dishwashers
LG Dishwasher Mode LDS5811
Try checking the wiring in the door for breaks and repair by cutting and splicing with electrical tape. This site has the Service Manual: http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Nov 17, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG Model LDS5811ST error code LE
LE is a motor problem.. You can find details in the service manual at this website link... http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Page 25 discusses that error code and possible solutions
Hope this helps...
Sep 06, 2008 | Dishwashers
Dishwasher
If you have confirmed power to dishwasher, you are pobably looking at a control board. I have only run into this one time on a LDS5811 so far. Parts on LG dishwashers have a two year warranty. You have to dissassemble the door to replace the part.
Aug 09, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
812 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
