Washer not draining and rinsing
My 3 month old Bosch 300 series washer is flashing and E13 error, will not drain completely and errors out when it is supposed to start the rinse cycle. Any suggestions?
Thank you-
Wet Towels
    Novelist:
  • 130 Answers
Hello Wet Towels, well to be honest outside of the test program I have never seen a fault code E13. If it was an error E03 I would check my water to make sure it was turned on, the cold inlet hose wasn't pinched, or debre filling the filter screens in the hose or water valve. That is what the care and use says about E03. In the back of your owners manual it tells you what the fault means and how to correct it. If this doesn't work call for service to resolve your issue. Hope this helps.
Posted on Aug 10, 2008
What does e13 on bosch exell 8 mean
This e13 code flashes with the "rinse" indicator light and indicates a blockage in the drain. This is often caused when you use too much detergent, or detergent that is not designed for a high-efficiency washer. Look for detergent with the letters "HE" on the package. Run a rinse cycle to remove any excess suds from the washer.
Mar 07, 2016 | Bosch Washing Machines
My 3 month old bosch 300 series washer isn't draining completely and errors at the start of the rinse cycle with E13 falshing along with the rinse light. Help!
the E-13 error code is a drain timeout code. This means the pump has run a certian amount of time without fully draining itself. This could be anything from a clogged drainline in your home to a clogged drainline in the machine, your pump is clogged, pump is burned up, no power to the pump, bad board etc. Most of the time its either something jammed in the pump, or its burned up (from something being jammed in it). Just have to take her apart to find out for sure.
Aug 10, 2008 | Bosch Washing Machines
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
Seal has holes
e13 is excessive drain time, normally down to blockages in the pump filter. this is at the front right hand side normally behind a flap and should unscrew counter clockwise.
Apr 10, 2014 | Bosch Nexxt 300 Series WFMC2201UC
My bosch washing machine model WFVC6450Uc/19 FD 9002/901476 has E:13 flashing. i was able to drain the water manually but now the door locked there is beeping sound when i try to start it. how to fix it
Hello & Welcome to FixYa
E13 error in your Bosch WFVC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Washing Machines
Bosch E13 error on washer - shows e-13 and door will not open.
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
E13
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
Here the tips... support/t7599677-error_code_13
Apr 25, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Dishes and inside the washer are not drying
Make sure that the drain hose is connected as per manufacturer instructions, and that there isn't a direct run down from the sink u-bend to the machine. The rinse agent effects dishes dry but has nothing with the water remaining in the machine. Good luck!
Sep 15, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washing Machines Logo
1,541 people viewed this question
Top Washing Machines Experts
