Question about Samsung HCM553W 55" Rear Projection Television
How much would it be to repair our t.v.?
The other day I was watching a movie on my television,then suddenly the t.v shut off, and then it came back on all by its self. The picture on the screen now appears to show the red color distorted and it is not matching up with the other colors. All the other colors are fine at the moment except the red. Please get back to me a.s.a.p, so that we can get a price evaluation on how much it would cost to get our television fixed. We have a Samsung Model # HCM 553 W, "55" Thanks Jon
    Problem Solver:
  • 5 Answers
There are two big Audio Amplifier Chips on the conversion board The first three solder connections on each of those chips commonly are burned and lose connection. You may just need to resolder the connections. These Audio Amps are running extremely hard and it is not uncommon for them to overheat and char the connections, or burn up the chip. But the cheapest fix is to resolder the joints first.
Dan Apted
TV Repairman
Anchorage, Alaska
Posted on Dec 10, 2009
The convergence chips have gone out. It costs about $300 if it's not under warranty. This is a common problem with all rear projection tv's.
Posted on Sep 16, 2008
PROSCAN 40LD45Q tv will not turn on
replace the power supply board!
Mar 02, 2013 | Proscan 40LD45Q TV
Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Dec 20, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
Suddenly hang while watching movie from external drive..we are trying to fix the problem by removing the power source then restart but no responce from the tv..no any viewing from the screen.
hi good day try to remove first the external drive their might be a cause while it suddenly hang. if you use with other external drive much better to easy isolate the problem. good luck
Aug 21, 2011 | Samsung Televison & Video
The TV shut off automatically but the powerlight is blinking
Your power source seems to be the problem, replace the part (located inside the television) and the problem will be solved.
Jul 18, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The other day my wife was watching tv and suddenly
Ur convergence is dying or well be dead.3D pics or shutdown.U must know how to solders? The parts in convergence board must change like ICS,and all it resistors.The websites Tv Repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u $300 for parts and labors.
Jan 14, 2010 | Proscan PS61670 61" Rear Projection...
Tv shut down wont go back on
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge,or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees.
Sep 06, 2009 | Protron PLTV-32 Television
Lost picture all color lines are at top of screen
Thats what happened your convergence went out, those parts can be found online for as little as 12.50 a piece. If you are good with solder its an easy fix. I found a guy on craigslist in denver who fixed it for 150
good luck
Feb 11, 2009 | Samsung PCN5425R 54" Rear Projection...
Input feed problem
I would suggest using the AV inputs instead of the coaxial input. It looks like there might be a tuner intermittent failure but using the AV inputs bypasses the tuner.
Good Luck.
Jul 21, 2008 | Proscan PS50670 50" Rear Projection...
Philips 26pf5320
Hello, one of possible solutions is to replace T7735 by the same type of transistor and L5753 (220uH use 470uH). This is a job for a technician. Best regards, Arpi
Apr 09, 2007 | Philips 26PF5320 26 in. LCD Television
Samsung HCM553W 55" Rear Projection Television Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
