HP 520a powered up, then the monitor shut off and the power light flashed about ten times and the computer shut off. It will not turn back on.
    Novelist:
    Scholar:
  • 141 Answers
Sounds like it may be your power supply. Try swapping it for one that you know works being careful to plug everything back as it was.
Posted on Aug 10, 2008
I got this computer from a friend of mine, and he hasnt used it in several months. I plugged the computer in, and the monitor and turned it on. It started up fine, I logged in, and then it asked me if it...
your computer have 2 complaints one. your computer have over heating problem of your cpu. so just remove heat sink and fan of ur cpu and clean after u must put 'heat sink compound on your cpu' after you can install heat sink back.
two, your computer is banded microsoft thats why when u loged on your pc. will ask automatic update so first you must log in to safe mode of xp ..click f8 button when u boot ur computer and login to safe mode.after you can install windows genuine remover you can download it from this site...http://www.brothersoft.com/removewga-download-62674.html..
Oct 06, 2011 | HP Hewlett Packard Pavilion a1016x PC...
MY HP 60 235DX WILL NOT TURN ON. I TOOK BATTERY OUT AND HELD DOWN POWER BUTTON, PLUGGED IT BACK IN AND IT STILL WILL NOT WORK. NO POWER LIGHT WHEN THE POWER CORD IS PLUGGED IN. BUT WHEN I DO PLUG IN...
fan turns? hear it and feel it.blow.? in must.
cd drive ejects? (button)
no text ever on the screen? this is first. all else more complex.
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
no beeps
no flashing caps lock key (codes) if yes, what code.
step one is get BIOS and its screens working
even using and external VGA monitor will help.
and the magic Fn+F4 key to turn that on.
hp is down this morning...(support pages)
the G60 series uses a CCFL lamp, that blows out (easy)
or its inverter.
if external monitor works, and flashlight trick works
CCFL back lamps are dead.
Aug 23, 2017 | HP G60-235DX Notebook
MAG innovision LT-926W 900W problem! After I turn on my computer, the screen immediately begins to flash and then goes black. The power is still on thought and so is my computer. If I take a flash light...
this means your power inverter inside the monitor is dead. This little gizmo lights up the monitor backlight. They dont fail all at once, but slowly die and give problems like you describe, you can order these online for your monitor , or find one on ebay for under 30 dollars, but unfortunately there is no fix, other than replacing the inverter. sorry. Please use the thumbs up rating if you find my answer helpful, albeit bad news. Take care. .
Aug 26, 2010 | Mag Innovision LT576s 15" Flat Panel LCD...
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 24, 2010 | HP 1730 LCD Monitor
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
Aug 29, 2017 | HP Pavilion dv6928us Notebook
My DELL flatcreen just went blank and is now flashing yellow light, won't turn on
Check and make sure your connections on the back of the PC are snug...and make sure you have a good connection at the back of the monitor.
Flashing light...is loss of signal.
Good Luck,
Mike
Nov 06, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
My hp lcd monitor won't power up
wat is the model n#. of your hp LCD?
just check the supply section board check the fuse all resistor and capacitor.
just use the multitester if u check all parts..
Feb 22, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
HP mx 70 Monitor
This is a problem usually with the Power Supply unit inside the Monitor. Often it is the Electrolytic Capacitors arround the Heatsink area. They dry out and go faulty.. It is generally a job for the "Shop" I get them all the time... But in saying that intermittent faults are the hardest to find.. If you do take it to a shop, ensure you get a firm "Quote" and explanation B4 proceeding.
May 14, 2007 | HP mx705 17" CRT Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
