GPX under cabinet cd play - KCCD6817DT
CD player is not working. I am getting not getting any error. It simply saying NO after some time.
Any idea?
SOURCE: JVC KD-G431 IN CAR CD PLAYER "000ZAAA" Error
I had the same problem. It started when I tried to play an MP3 track from a "Creative Zen Vision M" Media Player. The result was the same as you describe = Maddening. It was extremely annoying that the CD player did not work. I thought I had broken the equipment.
Then my wife read the product hand book , and noticed on page 2 http://jvcmobile.co.uk/documents/products/KD-G431%20Instructions.pdf it showed, where using a pen you can reset the equipment back to the original settings. I thought I might as well give a try. It worked = Fixed. Amazing. I was so relieved. Such an easy solution.
Give it a go. I reckon there is a good chance it will fix your problem, and you will also be very relieved. Just use a basic MP3 player in future. GOOD LUCK !!!
Posted on Mar 22, 2008
tech48
  • 624 Answers
SOURCE: Hello I have a Pioneer XC-L11
It is most likely that the laser pick up is bad. That is the part that reads the disc and is the most common reason. You can try a lens cleaning disc to see if it just needs to be cleaned, but if that does not work you will need to take it in for service. This problem can be caused by several different things, from the spindle motor (spins the disc), to the pick up (reads the disc), or even an IC that controls one of those things. Once you have cleaned the lens, you can also try cleaning the disc's. If a disc has a fingerprint or scratch in the area of the disc that is know as the TOC (table of contents), it will not read the disc. Fingerprints in other areas of the disc will cause the player to skip or even stop playing. I use windex and a soft cloth like a bath towel to clean the disc's, it works as good or better than the disc cleaning kits you can purchase, and it is much cheaper.
If none of this helps, it has a problem that only a trained technician can figure out with the proper test equipment. Then you must decide if it is worth getting fixed. Some service centers offer free estimates, but those are the ones that don't actually check your equipment first before giving an estimate. They just give you a ballpark figure that is usually pretty high. To get an acurate estimate you normally have to pay for it. A technicians time is worth money, my shop charges $25 for an estimate.That is pretty cheap. Some are as high as $65 for an estimate. But if you are paying for an estimate, they will normally at least troubleshoot the unit and determain just what the problem is, compared to a free estimate which is just a guess and a ballpark figure usually high to cover the cost no matter what the problem is. You may also end up paying much more for a repair when you get a free estimate, because you have already approved that amount, and many shops will charge you that much even if they find a simple problem that only takes 30 minutes to fix.
Replacing a pick up normally cost about $125 to $150 because the part can sometimes cost as much as $75.
I hope this was helpful for you and lets you make an informed decision. let me know if you need any more help.
Dave
Posted on Jul 13, 2008
SOURCE: cd player says error
i cant play mp3 usiing usb
Posted on Sep 15, 2008
SOURCE: Need owner's manual for GPX under-cabinet radio CD player
http://www.gpx.com/
then go to support
Posted on Dec 26, 2008
SOURCE: I have a stanton-vestax cd-11
Stanton-vestax CD33 I need universal cd player controller cable. 13 pins male to 13 pins male this is round conector.
Posted on Jun 13, 2009
How can I get the cds to play?
do u have the settings set right to cd player
Aug 30, 2014 | GPX Kc232S Under-Cabinet RadioGPXKC232S
A put in a cd and after about 40 seconds it stops playing a gives me an error signal.
Hello and good morning,
The Error it is saying, is player is dirty.
In the past what I have done and works 99 percent of the time, is I go down to like radio shack or best buy or almost any electronic supply, even stereo install stores will normally have a CD cleaning kit that comes with a fluid that you wipe on the blank CD with the applicator or towel it has in the package. What you will be doing is putting this blank CD that is designed ( with the cleaning solution) to go through your player and clean all the controls and contacts and components. You might have to run it through a few times, then when you think you are done and its is now clean, put a brand new CD or a CD that you know for sure it works, and try and play it again. 99% of the time, this will solve the problem. I hope this helps for you. Rock On!! Mike from fixya.
Aug 04, 2011 | GPX CRCD6306DT Clock Radio
Will not record but will play cd's
You don't say what the recorder does do when you try to record. Any messages?
One possibility - You have to use CD-Audio or CD-Music media for consumer CD recorders.There are probably a zillion logos plastered somewhere on the unit that say what media are compatible with it.
May 16, 2009 | GPX CDRW3500 CD Player
Built in Car CD player
get yourself a cd cleaner and clean the cd. then try another cd. if this does not work and if under the warranty take to the shop.
Oct 24, 2008 | Emerson PD6810 CD Boombox
GPX C3960 MP3/CD player
There's a good possibility batteries may have tarnished or slighty corroded the battery terminals on your unit. When this happens, the batteries can't make good electrical contact through the terminals and therefore, can't deliver power to the unit. In some cases, it is easy to remove the tarnish/corrosion by filing it away using a fine grain sandpaper. I've done this many times with different units with good success. I'm not saying that this may be your problem, but It's something to look into.
Aug 18, 2008 | GPX C3960 Personal CD Player
6 disc cd player in 2002 explorer won't work
ok welll its time for a new cd player they dont last that long any ways
May 27, 2008 | Car Audio & Video
My mp3 want go to the next song.
Mine was doing the same thing I found out that the music was in windows media and did not work and some was copy writed music. I found if I can get it copied to a cd and run it on real play under mp3 then put it on my MP3 it work then it does take a little work but I did like it. I did the Harry Potter books on cd that way. I had the cd s but I had to use Real Play to download.
Jan 11, 2008 | GPX MW3836 MP3 Player
Errors on loadind
Your cd-player fails to read the discs. assuming the disc isn't damaged your problem might result of many diffrent reasons, from dirty lens to bad mechanism, memory problem or bad circuit. You will need to have it checked by a professional technician.
Mar 16, 2006 | GPX CDP3104CK Personal CD Player
77 people viewed this question
 Grubhead
Grubhead
