You need to provide more information. What is it doing? Is it simply not powering on? If you are using the Slim Xbox make sure its in the right USB adapter. If your using an old Xbox try placing your adapter in different USB ports to see if that works. If none of this helps, try cleaning the sensors with a dry, soft cloth. It should still be under warranty just send it in if you cant get it to work after all this.
SOURCE: my kinect isnt working ever
Make sure that the power supply is secure, and thencheck the power supply light.
Make sure that the power supply is cool.
Plug the power supply into different wall outlet.
Disconnect all accessories
Remove the hard drive
Request a repair
click here to download repair guide
SOURCE: my xbox 360 wont load
There is no need to have
technical knowledge to do fix this problem,, just get xbox repair guide from
internet and follow the steps in it and fix your problem by your own....... click here to download microsoft xbox 360 console/.................................
SOURCE: my kinect sensor is plugged
Red light problem can
be fixed! there is a XBOX 360 repair guide available that covers this problem
and also all other common XBOX problems. You can get your copy XBOX 360 Repair
Guide, you can download it and get help to fix your console.
SOURCE: my xbox 360 kinect sensor it has to be updated.
Should come up automatically when you plug in the kinect
SOURCE: I have a xbox 360
A likely reason this problem is occurring is that you are drawing to much power from a single outlet. Try plugging in your Xbox to a different electrical socket. If this problem persists please comment so that I can try to further assist you.
A problem has occurred with your Kinect Sensor (C000022D)
A problem has occurred with your Kinect Sensor (C00000C2)
Here's what to do to fix the problem:
Solution 1: Update your console software
Update Required: An update has been found, to apply this update you must restart your console.
