Question about Danby Heating & Cooling
My air conditioner does not cool. the compressor kicks in but no cool.
  • 182 Answers
Low on freon
Posted on Aug 10, 2008
My frigidaire air conditioner model FAA060p7a will not cool the fan works fine but on cool the compressor does not kick on, if I turn the the temp knob you can hear it click behind the knob like its...
The problem here is the compressor.... it has failed and will not start. You can try to replace the capacitor and see if it will go but most likely the compressor is toast. I t will cost more to replace it then to buy a new unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Frigidaire FAA060P7A Air Conditioner
A/c runs cool for about 20 minutes and then does not cool anymore. keeps running but does not cool.
Is the compressor still running or has it kicked out? The normal problem is that the unit is low on freon and the compressor is not cooling because of this. If the compressor is kicking off an feels hot to the touch but the inside coil is sweating when the compressor kicked off the compressor is going bad. On an outside chance the thermostat can be going out if you turn it to off or all the way down you should hear an audible click and again when you turn it up normally its good if the click is audible. good luck
Aug 11, 2010 | Dometic Rooftop RV Air Conditioner
Compressor not kicking in on 'cool'; or ;dry'
Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
Jul 07, 2010 | Whirlpool ACQ122XK Air Conditioner
My 18000 btu Maytag window air conditioner does not cool. The compressor kicks on in an attempt to cool but no cool air comes out.
Hello my name is Heath it will be my pleasure to assist you. One thing I can suggest is try plugging the air conditioner into a surge protector.
Jul 01, 2010 | Maytag M6Y18F7A Air Conditioner
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
Air conditioner is not blowing cool air, but fan still blows
check the compressor with the ac running and make sure the compressor is kicking in and out in not the compressor might be bad or te clutch on te front of te compressor, sometimes u can get to much freon in them to i did it ounce
May 30, 2009 | 1998 Cadillac Eldorado
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Heating & Cooling Logo
43 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
