Question about GE Kitchen Ranges
I own a double wall oven....GE Model # JTP35WOM1WW. I noticed that the plastic covering on the control panel was peeling and mistakenly thought it was a clear plastic protective coating and tried to peel it off. Not good. It was the permanent control panel.....now looks terrible. Any suggestions on what to do????
    Novelist:
  • 130 Answers
Mariannejac the trouble is that the part you are talking about comes complete. You may try using some clear double sided tape. That is how most of these are attached.
Posted on Aug 10, 2008
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
JT980 trivection double wall oven, some buttons are not working
If the control circuit board is clean with no signs of grease or moisture deposits, it's almost always the membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You can download GE owner's manuals and installation instructions here.
Jan 09, 2013 | GE Profile JT980 30" Built-In Double Wall...
I have an older microwave oven and the plastic
i wont worry about it. it is for grease ewntrapment
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My mother's GE microwave oven has a large burn mark on the ceiling of the unit. She noticed some plastic parts on the floor of the unit. She bought the combination microwave-stove about four years ago and...
That would be the stirrer assembly. It consists of the stirrer motor, stirrer blade, and stirrer cover.
Without the stirrer in place, the oven will not cook evenly and may arc and spark.
Without the cover in place, food particles and grease can get on the waveguide and magnetron, and cause arcing damage.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you need to replace the stirrer motor, you'll probably have to pull the oven from the wall. You can download GE owner's manuals and installation instructions here.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Dec 02, 2008 | Microwave Ovens
GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 18, 2008 | GE JE1540 Microwave Oven
Model. jtp35wom1ww serial.AR6 18302Q. Double Oven will not heat properly. Takes 40 minutes to heat to 350.
Check to see if Lower element is red after 5 minutes. if not you are just heating on the broil unit at 110 volts (1/4 of its full watts), may never get much hotter than 300 that way. if bake isn't red it may need to be replaced.
Jun 19, 2008 | GE Kitchen Ranges
GE JVM 1650BB Microwave
F3 indicates a failed touch panel. It usually comes up after the key is shorted for 30 seconds.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off. You have to make sure all the old adhesive is off.
Then peel the backing paper from the new keypad and carefully press the new keypad in place. You need to be precise - you cannot apply it, peel it off, then reapply it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 22, 2008 | GE JVM1650 1000 Watts Microwave Oven
Micriowave key panel
Jan 29, 2008 | Samsung MW1030WA Microwave Oven
Ge double wall oven repair
You need to tell us the model number. I can then give you specific information.
Nov 17, 2007 | Ovens
Kitchen Ranges Logo
126 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
