Question about Maytag Microwave Ovens
My microwave does not cook the food. Everything else works. The timer, the fan, the turn table. I used it thursday night to make popcorn and when I tried to heat up a Lean Cuisine panini sandwich on Friday it would not heat it. Thanks for your help! Patsy
  • 725 Answers
First I would check the door switch ... if the switchs are good then it may be a magatron...if younger then 5year old you can call for service..
Posted on Aug 10, 2008
Why does microwave turn itself off occasionally after a minute or two
There is a fan inside that blows air across the electromagnet that cooks your food. It gets hot! The fan is most likely broken or spinning to slow to keep the electromagnet cool enough. There is a thermal sensor on the electromagnet to shut off the oven if it gets to hot to prevent it from catching on fire or melting everything inside the oven control area.
Nov 02, 2017 | In Microwave Ovens
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Does not cook food. the microwave oven appears to be working but it doesn't cook the food. Turn-table works, timer works, the light in the oven is on but my food does not cook, defrost or warmed up.
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
Jan 26, 2010 | Sunbeam SBM1000 Microwave Oven
My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Aug 29, 2009 | Frigidaire FMV156DC Microwave Oven
Clock works, timer works-but turntable and other functions stoppe
you have a bad control board . this board had 2 relays one for the magntron and one for the turntable and the cooling fan together . when the turntable goes out so does the cooling fanm and the microwave overheats ...... there is no good fix for this , the control will cost more than a new microwave . please do not use with this happening . i have see them start on fire when it overheats . please be carefull good luck
Jan 15, 2009 | Emerson MW8108P Microwave Oven
Toaster Master 1979 has less power
Because the microwave energy is beamed into the interior of the microwave and then dispersed by a metallic "stirrer," the pattern of the energy can be fairly consistent, rather than completely random. But this pattern sometimes causes certain portions of the food to overcook (creating tough spots) and others to undercook. A microwave oven with a carousel is far better at cooking the food consistently--the pattern becomes quite random while the carousel is turning.
Nov 13, 2008 | Microwave Ovens
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
Jan 06, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
292 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
