Question about Plantronics 510 Voyager Headset - PLN-510 Headset
Connection lost between Plantronics 510 Voyager and blackberry
After activating Plantronics 510 Voyager it gets disconnected within few seconds, again I activate and same happens after few seconds.
Please help
I ave exactley the same problem on my Samsung sgh g600
Posted on Oct 07, 2008
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
My headset will not hold the charge very long - is there a fix for this - is there a battery somewhere on this unit that can be replaced?
Unfortunately, the Plantronics Voyager 510 Bluetooth headset does not have a replaceable battery, it is "hard wired". However the 510 headset does have a one year warranty, so Plantronics will replace it within the warranty period. If it's out of warranty, you can buy a replacement if you'd like or buy the newer version which is the Plantronics Voyager Pro+, which is just a newer, slimmer model and it also has newer technology (for the same cost). Here are the links below.
Here is the link to the Plantronics 510 replacement headset.
Here is the link to the Plantronics Voyager Pro+.
Aug 25, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Can't hear my pc to head set..can u help
Hearing a Plantronics Voyager 510 headset through a computer:
To use a Plantronics Voyager 510 headset through your computer, you either need a USB Bluetooth adapter or you must have Bluetooth built in to your computer. Once the Voyager 510 headset is "connected" to your pc (by one of the mentioned ways), you may need to go into the control panel on the computer or the specific software program being used to set the Plantronics Voyager 510 headset as the "default device". Keep in mind that the headset has to be powered on and to also have to activate the headset to connect to the Bluetooth adapter or computer.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 925 connects to my Blackberry Bold but disconnects within 2 seconds
Looks like there is a battle between two or more equipment items.
Are you using more bluetooth equipment on your Blackberry?
Then delete them from your phone. And try pairing again with the 925.
Then activate the option for automatic connecting with the 925.
After this you can connect the other bluetooth equipment but do not set either of them on automatic connection.
Hope this will work.
Aug 02, 2011 | Plantronics Discovery 925 Bluetooth...
I have htc thunderbolt when i scan it wont find my bluetooth im wondering if there compatible?
Here is a solution that might work on your HTC Thundermug. The User's Guide indicates "activate bluetooth pairing mode by pressing the Power button". It should indicate to press and hold the power button. Pressing and holding resulted in the headset being recognized within 5 seconds by the HTC Thunderbolt. This is a problem with the User's Guide.
How to Pair the Plantronics 510 Headset
Good Luck from Headsets Direct!
Jun 27, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do i conect to my phone
Connecting or Pairing your Plantronics Voyager 510 Bluetooth Headset will take less than a minute. Click on the following link for instructions with photo so you know which buttons to press:
Pair Plantronics 510 Headset
Apr 23, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
Earpiece slipped off the plantronics bluetooth,and i want to know if there is anything to help put it together again.
my plantronics 510 voyager did the same thing. try putting the earpiece back on to the main bluetooth and wrapping a small rubber band BETWEEN THE TWO. the object is to put some opposing pressure on the earpiece to force it to stay on. it'll work at least till you get anoter earpiece
Oct 05, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
176 people viewed this question
Top Plantronics Radio Communications Experts
Ed Nelson
Ed Nelson
waldofrog
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
