Question about IBM ThinkPad R40 Notebook
Sound prob i have no sound from any speakers. if i adjust volume i can hear a 'crackle' at the point where i adjust - eg - silence crackle, silence crackle. any advice?? ef
  • devilsduce Jan 24, 2009
    r40 had sound now no sound i hook up usb speakers and full volume and I can hear very little sound but i can hear it when i have my ear right up against the speaker the speakers do work as they are new and tested them on other laptop sound drivers never changed any help would be good Oh yeah cd rom shows up in my computer then gone then its there then gone i do the add new hardware and its back then gone again I like my Ibm but damn this is painfull
Thinkpad r40e
it may be the driver but it just cut out mid track,
Posted on Aug 10, 2008
    Scholar:
  • 46 Answers
Let me know what the Type Numeric Number and Model Number on the bottom of the laptop is. I can look on IBM website and see where the hard drive is in located to the speaker. It has happen on some HP and Toshiba I know from experience where the hard drive causes the speakers to crackle. Not sure why, maybe not enough shielding. The type has 4 Numeric Characters and the Model has 3 Alpha/Numeric Characters.
Let me know
comier957
SOURCE:
Audio problem streaming media via ROKU and RCA players. Constantly have to adjust volume to hear them talk, but then the music/sound effects blast you out.
It sounds like you're using a set of stereo speakers to play a surround sound output. I would try going in the TV menu and turning off surround sound
Dec 23, 2013 | Televison & Video
Speaker rattle
yes try to change the speaker
Jun 18, 2017 | Samsung Cell Phones
Itube fatman mk1 volume dial making a crackling noise
Try spraying switch cleaner into the volume control and working it from side to side. It sounds like it may be worn, dirty or corroded.
Oct 31, 2012 | Cars & Trucks
How do you get the RX icon to turn off? The unit just has a contant fuzzy buzz.
RX represents "receive" This indication will be present whenever the speaker is producing audio. The "buzz" you're talking about is probably static, and is technically audio from the speaker. To silence the "buzz" adjust the squelch just until the speaker falls silent. The RX indication should be off at this point.
It is important to note that the squelch is designed to keep the speaker silent until a signal is detected. You adjust the squelch based on the level of static at a particular time and at a particular location. The static level may change depending on those variables. If you adjust the squelch well beyond the point that the speaker is silenced, you may not be able to hear transmissions or calls to you unless the caller's transmitter is physically close to you. This is why the squelch should be adjusted only until the static is stopped and the speaker is silenced.
I hope this helps and good luck!
Apr 30, 2012 | Radio Communications
My ipod crackles and my hearing seems to be getting damaged
Id say you should go see a doctor. But for now id say that you should do your best to not listen to it for a while as it can affect hearing. try to use full on speakers if you can. On you tube there are a few Sub-Woofer sound tests you can do. Try playing one (low volume) and repeat. (not a song one)
http://www.teenbuzz.org/ also to hear which frequencies are out of range to you click here. ( click the second icon on the list further down the page)
But yeah go see a doctor. Perhaps some ear drops.
Sep 01, 2009 | Apple iPod touch
There is crackling coming from the horn as soon as the power is turned on, the level of the crackle does not alter with the volume control, the cabinet performs fine otherwise ?????
The horn speaker is wearing out. Inside speakers, there is a magnet, the speaker part is attached to a cone that slides over the magnet, They tend to make crackling noises. Try very gently to apply pressure to the horn and then release. If you hear a scratching sound, the horn will need to be replaced
Jun 27, 2009 | Mackie SRM-450 System
Sound crackle on warmup, now no sound at all
Turn your volume up slowly if you can hear audio. If no audio at all. Could be loose/cut wiring on the speakers.If both speakers are dead could be fault on amplifier side.
Apr 04, 2009 | Televison & Video
Speakers crackle, then sporadically stop
Sounds like an amplifer fault. Many of these Midi system use a large black IC attached to a metal heatsink. They control both the power amp and pre amp on both channels. When they go wrong they can cause all sorts of effects,
If you can repair things I would look at that. If not get ready for a large bill. If it's the IC some are expensive, it does most of the work!
Jan 25, 2009 | Sony CMT-HP7 CD Shelf System
My wireless speakers are not working i don't know why
After some research i came with the solution!!! First Turn off the home theater and turn it on again,lower the volume completely. Then on the dvd unit press the fast forward key>>>> while at the same time you press the number 3 on the remote control. A letter p is going to show oh the display. When this is happening there is a small button on the receiver on the back, you might need a thin object to reach the botton and press it. Press it once and the light will change from red to green. To finish up repeat the fast forwar>>>> key on the unit while pressing #3 on the controller and boom!!!!! the w1 will stop flashing and your surround speakers are rocking!!!!! enjoy it!!!!!!
Dec 13, 2008 | Panasonic SC-PT960 Theater System with...
IBM ThinkPad R40 Notebook Logo
148 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
