10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
found this online hope it helps...
42"plasma purchased nov-07.I was watching t.v and it just shut off and nothing
no blinking light nothing so changed the fuses in the back and went to turn the
power back on and all i get now is 10 blinks then nothing.I have the t.v at the
service man and he is telling me its the power board and after the price of the
board and his labor charge it will be around $300.
G.L. scroll down for image
SOURCE: panasonic viera wont come on
The problem is not the power supply, is with the tunner board voltage. change the P.A board fix the problem.
SOURCE: th50px80u panasonic tv will not power on blinks 10
blinking 10 times is an indicatron that the power module has failed. The sensor detects a fault on one of its internal boards( 3) and goes into shut down protection mode. You cannot play board swap jockey to fix this TV it will end up costing 3 times more if you attempt it. It requires a specialist knowledge,tools and ability to read a circuit diagram and ensure voltages are consistent with manufacturers recommendations across all boards.
If its got extended warranty claim now before itv expires.
if not get quotes for repair from a professional It;s not a DIY
THanks for using FIXYA Please rate my help++++ Thank you
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
