Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Light engine replacement
Ok lets start. I am an electronic tech, but this is the first DLP set I have worked on. It cam in with the notorius red screen. Tried the memint and factory reset. No advaile, so order in an complete light engine. After replacing the light engine I now have an green screen..In the service menu you cannot adjust the drives or cutoffs. On the old light engine I could adjust these. Any techs have input on this..Or ask me more questions and I will answer them.
PPS I also saw that (from another post) you can hook up laptop to set? if so anyone know how..
Chuck
  • Charles Smith
    Charles Smith Aug 13, 2008
    the frist LE, was showing nothing but red, buit you could adjust the ICS service adjustments. EG: red cutoff . With the new LE, its all green and you cannot adjust R ,G, B, cutoff's or drives.
    Checked all cables including the ribbon cable for cuts or extreem bends..They are ok..I order the LE right form hitachi Customer relations giving them my serial/model #'s..
Good Day, almost tech;
Give me some help:
1. What input are you useing, if any?
2. Do you have OSD or VIDEO??
3. Did you reinstall old 'LE' back into TV???
4. Did you double check the TV's Model number vs part number received????
Let me know, big IRISH.
Posted on Aug 13, 2008
  • 927 Answers
Good Day, tech;
Let's suspect poor cable connections or pinched, BUT I have received bad light engines. Make sure you ordered the correct Part Number. There are two (models) of them; check Model Number, some are 50V500 and 50V500A.
What's your input to indicate red or green???
Let me know if this helpful, big IRISH.
Posted on Aug 12, 2008
SOURCE:
Why does my DLP 60 inch Mitsubishi TV keep turning off and flashing a red light?
Your repair tech hinted correct. Although the bad connection will likely be in the power supply, it actualy can sit everywhere the power goes. Can be anordinary plug / connector with a little oxidatin, or a dab soldering point. Or perhaps a electrolitic cap, slowely dying.
Let the tech do his job. He has the tools, education and skills to keep your beloved TV alive.
Apr 01, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Dlp red haze
Inside the light engine all the mirrors are probably fogged. If you attempt to clean them make sure, I repeat make sure they go back the same direction and place they come out of... let me know what you find out : Expert-tech / Sam
Mar 27, 2012 | LG Televison & Video
What causes the yellowish hue in the centre of the screen
There are several different types of projection sets: some use 3 picture tubes, red,green,blue--if this kind of set is what you have the coolant used in the blue tube is bad-----this type of problem leaves red and green which = yellow.
Most common in Samsung, Philips, Magnavox type sets.
If it is a newer set without picture tubes (a dlp style set) yellow in the middle of the screen would denote a damaged optical light engine.
Let me know brand, model number, date made----all are on back of set.
SD TECH
Feb 25, 2011 | Televison & Video
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Hi I have TV AKAI start projecting a red
rear projection tv can be crt or dlp, if crt, try to adjust red color using the customer convergence feature, you will find it in the customer menu usually under advance feature or video settings, some tvs will just give the convergence caption right on the menu listing. If this does not help then the tv might be in need of some convergence circuit repair, probably one of the power outs is damages and needs to be replaced. If it is a dlp if the red shade extends all over the screen or located in a certain area of the screen then i would have the tech check for light engine trouble, this is a common problem on some dlp systems.if i answered your question satisfactorily please leave your positive feed back. thanks
Aug 26, 2009 | Akai Televison & Video
SAMSUNG DLP HL P4663W 46 PROBLEM IS RIGHT QUARTER OF SCREEN MIRRORING / DOUBLE IMAGES, COLOURS RED, GREEN VERY VIVID. REST OF SCREEN PERFECT. THIS HAPPENS WHEN ALL INPUTS DETATCHED AND TV ALONE TURNED ON....
sound like light engine bad mirrors get stuck on ic dmmd "digtal micro mirror device the mirrors get stuct replac ic if u do not have smd soldering exp do not attemt but u can order dmmd ic from samsung or nte electronics.con 50.00$ ic this should fix ur problem have exep tech solder in 4 you 2 replace light engine $900 u get the picture tryin to save u a$ with perfect results hope this help u later bud!!!!!!!!!!!!!!!!!!!!!! shan
Aug 08, 2009 | Samsung Televison & Video
I have a Mitsubishi WD-52525 DLP
if you have a picture the engine is probably ok. this is a common problem with this set.it is probably the main chassis (DM or FMT)
visit www.tv-techs.com
Dec 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
189 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
