Question about HP LaserJet 3055 All-In-One Printer
Scanning? I want to use the scanner on my HP3055. So I downloaded the install software but it won't let me install it. It says: no printer detected, make sure printer is turned on etc.. but I can still print, no problem there? What do u think?
  • John Smith
    John Smith May 11, 2010
    are you using vista or XP
I had a similar and found out this model was particular about using "well-powered" USB ports. If you have a powered hub see if that makes a difference for you.
Posted on Aug 11, 2008
Cant find scanner driver or software for hp 3055
Hi
Use a Normal TWIN driver that appears in any software that allows you to scan or in Windows click on Start, Device and Printers, Select your HP3055 and SCAN
Dec 09, 2014 | HP LaserJet 3050 All-In-One Printer
Hello I have a hp printer and I am trying to scan a document to my pc.but i get this error msg 'scanning error'try scanning from pc or check documentation.
You must also install the scanner driver too, and also the scanner management software, if installed properly one can scan fro paint, Word, Publisher and the like, as well as the software that comes with the scanner. There are also other scanner programs on the net, Vuescan, doesn't even need a driver to work, there is scantopdf, and quite a number of others. So go to the HP website and download the scanning software and the scan manager and install them, then you will be able to use the scanner as it was intended.
Jul 12, 2010 | Office Equipment & Supplies
Auto detection can not be set as default
A 'Driver' is only the software portion to connect two hardwares. You need to install a printer driver for Printer, or a DVD driver for a DVD drive. Similarly, the scanner driver just connects the scanner to the computer.
You need to use a Scanning software to use the scanner. Canon offers CapturePerfect 3, using which you scan documents, do rotation, convert to PDF etc. CP3 has option to detect the page size. CP2 is available free of cost from Canon sites. CP3 comes with the scanner.
S. Mohan, Chennai, India
Apr 01, 2010 | Canon DR-5010C Scanner
Nothing happens when i press scan on a hp f4280 have i missed something?
Install the software/driver for scanner and you can try scanning (Mspaint go to File> From Scanner or Camera>) if your device is configured right and software is installed correctly it should detect the default scanner.
Nov 18, 2009 | HP DeskJet F4280 All In One Printer InkJet
Dell 810 all in one printer/scanner not scanning
scanning is a bit of a trick. You have to have hardware to scan with, and SOFTWARE to receive images. Make sure the scanners imaging software suite has been installed, OR, you can use the scanner manager in windows to scan with. Just select the dell 810 as the "scanner source" and click "scan". that should do it.
Oct 26, 2009 | Dell 810 All-In-One InkJet Printer
How do you use the scanner on an epxon sx105
You need to have Epson software installed, or the scanner will not work.
Once the software is installed , you open Epson software and follow on screen instructions to scan.
After software is installed, you can also start scanning using the button on the printer.
Here Epson download page, in case you need to download the software:
Oct 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer works scanner does not
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner hp 5610 not working
Scanners come with scanning software. This software must be installed for the scanner to work. I would install the scanning software, and try scanning again.
Feb 02, 2009 | HP Officejet 5610 All-In-One InkJet...
I have never used my scanner
Make sure that you install Drivers and Programs/Software that you got when you purchased this printer/scanner first.
Usually, Scanning Program Comes with the Scanner and they are very easy to use.
If you do not have the CD that came with, then go to Epson site and download should be available for you.
If Scanning software is not available from Epson Website, then Download Driver at least then install.
You should be able to find any Free image editing program and usually they have Scanning Capability.
Jan 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Scaner is not working of hp3055 color laserjet printer
Step 1:. Check Hardware Driver Installed Properly
- My Computer-Properties-Hardware-Device Manager
- If Yellow mark in printer and Scanner field, the Printer
driver not installed properly.
- So reinstall Printer Software
Step 2: If Scanner Option only not working,
- Go to Scanner Settings(Start-Programs.....)
- Choose Correct Scanner Name.
Or
- Press the Scanner button in hp 3055
- If Hardware driver was installed correctly, its automatically
deduct on your PC
Jul 02, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 3055 All-In-One Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
