Question about Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens
NIKON 50mm 1.8 ---"Err" on top panel display if aperture setting is not at f1.8
Hi, I own a Nikon D80 and I just bought a NIKON 50mm1.8D lens. The aperture ring is locked at f22 as it should be for the lens to work but the problem is at whatever mode I'm shooting in (M,or A), "Err" shows up every time on the top panel display if the aperture is not set at f1.8 via the command dial and the pictures are totally blown out. Even on S mode where the camera sets the aperture according to the shutter speed you select, if the shutter speed I select requires and aperture of anything other than f1.8, the same thing happens and in all cases, I have to turn my camera off and back on to continue shooting but only at f1.8. I've never had this problem with my kit lens and I still don't (nikonDX18-135mm). With my kit lens, I could freely set all the possible aperture values for this lens and everything is fine. Do you think there is something wrong with my camera body or did I receive a defective lens?
  • mike23nguyen Aug 16, 2008
    Here's an update on my problem: I took my gear to a professional camera shop to test my new lens on a different camera and it worked fine. We attached another brand new lens on my D80 and "Err" showed up again. Although my D80 works fine with my other lens, it seems the problem only happens with a "fixed lens". I think it's safe to say that the problem lies in the camera body. I'm going to get my camera checked out soon, so I'll keep you posted as soon as possible.
  • Anonymous Aug 16, 2008
    how strange.
    my camera also works just fine with all my other lenses.
    except when i just mount the lens, it goes on like this:
    http://static.photo.net/attachments/bboa...
    i then have to hold the lens release button, and turn the lens back and forth until the aperture opens all the way. it is then that this Err problem occurs when i try to shoot at anything over f1.8.
    i guess i should go get it checked out too.
This same thing is happening to me on my D70s.
i posted about it at photo.net and everyone is stumped.
http://photo.net/nikon-camera-forum/00Q6eB
i already returned the lens and got a new one...
same problem. i don't know what's wrong.
does anyone here have any insight?
Posted on Aug 16, 2008
SOURCE:
Where is the aperture ring on d80 Nikon
If you are using an older lens the aperture ring will be close to the camera body when the lens is on the camera. In order to set the aperture with a D80 and older lens you must set the aperture ring to "22" or the highest number on the aperture ring available. For newer lenses there is no aperture ring. You set the aperture by setting the dial on the top left of the D80 to "A" for Aperture Priority. You then set the aperture by rotating the front dial on the right side of the camera under the shutter release button. On older lenses, after setting the aperture ring to the highest number, you then set the aperture in the same manner.
Sep 22, 2014 | Nikon D80 Digital Camera with 18-135mm...
I have a nikon D80 purchased with a 18-135mm kit lens which I have found surprisingly good and very sharp as confirmed by Rockwell etc. I bought a Nikon 50mm 1.8D based on the fantastic claims of sharpness...
I don't think you're going to see much difference in sharpness between the two lenses, because they're both such good lenses.
You can use the lens in any exposure mode. Leave the aperture ring set at f/22. Control the aperture from the camera body, the same way you do it with the 18-135mm. The zoom doesn't have an aperture ring --- so just set the ring on the 50mm to f/22 and then pretend it doesn't have one either.
Feb 01, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
ERR comes on screen...
Pull all the batteries, wait 30 seconds, put in a completely different card, put batteries back in and turn on and format the card--sometimes works
Aug 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80. When i turn the camera on i cant shoot any photos in the top right corner of the display i get the letter F ee flashing
Page 132 of the D80 manual explains the FEE error: Lens aperture ring not set to the minimum aperture. That would be the largest number which may be 22.
Jul 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
While my Nikon D80 is Error 09, can I update the firmware?
Have you e-mailed or called the techs at Nikon with your problem?
Jan 06, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Err
You did not mention what error mesage you got. If it is a flashing "F--" then it has something to do with your lens.
This usually happens to lenses that have an aperture ring. Do the following:
1. Turn off your camera.
2. Move the aperture ring clockwise and lock it
3. Turn on the camera and see if this works
If this does not work, unlock the aperture ring and move it counter-clockwise then lock it again.
This should fix your problem
Jan 01, 2010 | Nikon D80 Digital Camera with 18-135mm...
Err with f4 and r11 display
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
Nov 27, 2009 | Nikon D80 Digital Camera with 18-135mm...
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Feb 28, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Control Panel display no information.
Do you mean the control panel on top or the big LCD on the back?
The display on top should be showing you stuff like the shutter speed and aperture as you take the picture.
The display on the back will not show you the picture while you're taking it. The D80 does not have a Live View capability.
Sep 17, 2008 | Nikon D80 Digital Camera with 18-200mm...
Nikon Normal AF Nikkor 50mm f/1.8D Autofocus Lens Logo
564 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
