My motorola rizr won't charge on either of my wall charger i then hooked it up to my usb cord with my computer and it will stay on (still not charging) and once i unplugg it, it will power down. it won't show charging on anything
i have motorola q i have problem to charging he not charging in the usb in my computer i have motorola q i have problem to charging he not charging in the usb in my computer
You can't post conmments that contain an email address.
Computer will not charge your phone if the computer is off, may stop charging during standby or sleep mode. If failure to charge over night was on wall charger its a problem with charger/cable. OR your phones battery is junk.
try charging on a wall charger? im assuming you have a usb wall connector to match your computer charger like i do, also try it on different options besides mass storage.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Seems like it may be your wall charger.
I would inspect your connectors (both charger & phone) as well though (for dirt or debris).
I would also suggest using Motorola's wall chargers, the products seem to charge best with them rather than the after-market knock-offs which also seem to damage the phones connectors on some models.
Motorola provides a USB driver for just charging the W370. I installed it using the installation instructions from the Motorola website, but it just wouldn't work. The USB driver would install but would not activate (error Type 10). The W370 said that it could not charge. I recommend not bothering with this device driver, at least not with Windows XP.
However, I did figure out how to get the W370 charging from a USB port by trial and error. It's a pretty simple process.
1. Before plugging in the USB cable, turn on the W370 and wait for it to fully boot.
2. Connect the phone to the USB port of the computer.
3. When the phone asks "Connect phone as storage Device?", press the phone's left soft key, choosing "YES".
4. The phone will say "Please Wait...... Connecting Phone as Storage Device"
5. Eventually, the phone will display a white screen with the message, "In storage mode, no regular phone activities can be done."
6. Flip the phone closed. The yellow battery indicator will be lit. The phone is charging.
You'll note that the computer will see the W370 as a storage device with around 512 Megabytes of free memory, with empty "picture" and "sound" directories. The W370 appears to be a generic mass storage device to the computer. No special device driver is needed to charge the W370!
