Question about Hitachi 43FDX20B 43" Rear Projection Television
Resisters questions I have the same tv model and same problem. I think I understand the IC replacement issue (I've found a 2-pack for $22 on-line...do I need to replace 2?) but I'm not sure about the resisters. You mentioned one would need the location numbers and to research the value of the burnt resisters. How do I locate these...where do I look....what do I do from here? Thanks!
  • 51 Answers
Its best to replace both IC's. As far as the resistors, there are location #'s marked on the board where the resistors are mounted. If any look burnt, get the location numbers off the board, and your model # and email me @ halselectronics@comcast.net. I will get you the resistor values.
Posted on Aug 12, 2008
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Problems with Cobra 142 GTL
the diode and missing resisters are and caps are probably the culprits.
Feb 01, 2012 | Cobra Radio Communications
SAMSUNG 61HL617 TV COME AND LATER ON IN SCREEN COMING LINE CROSSING BUT STILL LOOKING PICTURE
This is 1 of 2 problems. 1; Convergence(depending on the model of the TV, the convergence ic's will have cold solder joints) 2: vertical ic issues.
If they are different colored lines & the picture also bends, it's a convergence problem. Else suspect a vertical problem. In the case of vertical issues, most of the time it's a defective capacitor (or cold solder joints.).
If it's the 3-crt kind of big screen, it's possible for one of the tubes to be going bad.
It would be best to contact a pro to take a look on your TV and replace the defective components. This should not cost you too much.
Feb 19, 2010 | Televison & Video
R-22 vs R-134A
not a good idea to swap gas coz need to change tx valve and flush system and use polyester oil,cost a lot. ur best options is to repair, pretty sure it can be soldered
Jun 09, 2009 | Heating & Cooling
I have a Carrier 4 ton unit model number 661CJ048-A which is charged with R-22 capacity is 9,25lbs. It has developed a leak at the evaporator coil. It has rust on the coils which from what I understand...
First your system is 22 and 134A is a auto AC refrigerant. I have never seen it used in residential ac. I have been in AC business for 45 years. The new refrigerant is 410A or Puron. But you can not use it. Your outside unit is set up for 22. Mix 134A with the oil used in a 22 system is not done. You need to get the correct coil for your system. They are going to make 22 for years. They now have a Drop in for 22 called NU22. I know times are tough but you may have to get a Service Tech anyway.
Jun 09, 2009 | Whirlwind FH-778 Air Conditioner
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
Hitachi 46F500 46 in. is still bad
if you found the burnt resisters after you replaced the ic you probably burnt the ic out again,
Jan 24, 2008 | Hitachi 46F500 46" Rear Projection...
65 in JVC with a possible convergence mis-alignment
2 Convergance ic and have to check resisters · http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 20, 2007 | JVC AV-56WP30 56" Rear Projection...
Sony HDTV Convergence Issue
No, You will not solve the problem with only changing the convergence IC, associated resisters may also be required.
Beside of that, after spending time to get parts and replace the ICs, you need to make and adjustment the color lines (about 14 lines)
This adjustment without experience will take you about 3 to 4 times and 4 hours each to get thing right (if you areskillfull, most of people failed this adjustment).. The total time spend for this problem would take you full 24 working hours.
I successfully adjusted one set of my big TV (95%, need more more round)), on another set one I failed.
Nov 30, 2007 | Televison & Video
Samsung HCN473WX
you may need to do convergence to align the colors up.
the only thing other than the ic that need to be replaced are resisters and if the resisters are bad you would not be able to move one of the colors, and blow out the ic you just installed.
Nov 04, 2007 | Samsung HC-P4752W 47" Rear Projection...
Hitachi 43FDX20B 43" Rear Projection Television Logo
83 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
