Question about Pantech Duo Smartphone
Ringer setting I've just bought a Pantech Duo, and I'm wondering if the ringer setting is able to ring in sound AND vibrate. On the profile settings, it just says only vibrate or ring, not both. Is that as far as it goes, or is there more somewhere else in it's settings?
  • rachel_lynn Mar 27, 2009
    i have the same problem. i can't figure it out for nothin. i think you can get a usb cord and hook your phone up to the computer and download the mobile registry. idk i've read about it and when i get a usb cord i'm going to try it. to see if it works.
    Problem Solver:
  • 7 Answers
Go to your profile settings and hilight the profile you want to use such as normal etc. hit menu then edit and change the ring type to vibrate/ring
Posted on Aug 10, 2008
SOURCE:
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
My nokia 1100 vibrate only but there is no ring i cheeked ringer and ringer ways all are ok please help me
Have you set it on Silent profile?
Press the power key once and select Normal profile. The phone will ring and vibrate in this profile.
May 31, 2011 | Nokia 1100
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
How to change ringtone
that setting is in the ringer profile section... you have to set it for each profile ....
Go to
SETTINGS
AUDIO
(ringer profile) DETAIL [change]
VOICEMAIL [change] select the sound/ringer
You must do this for EACH profile setting if you use a different profile
Aug 30, 2009 | Motorola Mobility RAZR V3
The phone does not ring - ringer is off.
firstly read the operations manual for that phone look on how to adjust the settings of your phone it probably sure was indicated there, because the way i see from what you posted it has no internal circuitry prob. it just needed an adjustment.. hope this advice helps... ;-)
May 24, 2009 | Panasonic KX-TG2343 Cordless Phone
Phone does not ring. display shows call is in progress then rings once and goes to voicemail
Please check your Profile settings Silent or No ringer ,if all option is enables please change your cell phone's buzzer
Dec 31, 2008 | Pantech Duo Smartphone
Ringer
go into profile and set ur message setting 2 silent and ur ringing tone 2 set anytone./.it wont make noise. reply me
Jun 05, 2008 | Samsung C417 Cellular Phone
Pantech C120
change the speaker on the phones and also have the ringer check on the main-board.
Mar 18, 2008 | Pantech C120 Cellular Phone
Alltel pantech camera cell phone pn-218
Check user customizable profile. Whether it is set Vibrator mode in General mode. Even by key press mistake it might happens. Check profiles section. if you feel Risky Contact authorised mobile service stations. thank you !
Dec 23, 2007 | Nokia 1100
Pantech Duo Smartphone Logo
157 people viewed this question
Top Pantech Computers & Internet Experts
Ekse
Marvin
Marvin
Gadget Corner
Gadget Corner
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
