Question about Ruud UAKA030 Air Conditioner
CAN' READ PLATE ON A/C - CAN'T TELL TONNAGE
I CAN'T READ PLATE ON A/C UNIT. I DON'T KNOW TONNAGE. COMPRESSOR HAS THE FOLLOWING INFO IT WAS HARD TO READ ALSO, MODEL-SRD6-0225-P4VC SERIAL 84B 12266 CAN YOU TELL ME THE TONNAGE OF THE UNIT FROM THIS . THE ONLY REASON I TYPED IN THAT A/C UNIT THE SYSTEM WOULD NOT ME SEND THE MESSAGE WITHOUT USING THE NEW RUUD A/C UNITS
    Problem Solver:
  • 15 Answers
That comp is a 25k btu depending on the age of the unit it is a 2 ton or 2 1/2
Posted on Feb 04, 2009
6ya staff
SOURCE:
I have an older Amana Prestige ii air conditioner and I need the tonnage, serial number or model number. The tag information over time has disappeared.
Can you read the plate on the compressor? If so, you can determine the BTUs from there. Roughly 12,000 per ton.
Mar 05, 2018 | Amana Heating & Cooling
Mitsubish AC Model FDC 51 BA Q.1: what is capacity of this AC in tons? q.2: what is running current in amps?
Here is a YouTube video that helps you calculate tonnage of an AC.
The only way to know the running current if it's not on the AC info plate with all the other info is to measure it.
Calculating tonnage of your air conditioner
Oct 12, 2017 | Heating & Cooling
Q.1 : Mitsubishi AC model FDC-51BA how much capacity this AC has in tons Q.2 : What is running current in amps
Oct 12, 2017 | Mitsubishi Heating & Cooling
Does the outside compressor tonnage need to be the same tonnage as the airhandler?
when the outside and inside units are both the same size it's referred to as a 'matched' system, which is what 99 percent of all units are.
There are instances when the outside unit is bigger/smaller than the inside unit but as a rule you want the outside and inside units to be the same tonnage.
Aug 05, 2011 | Goodman Heating & Cooling
Cant find a price on the unit anywhere and just need the info to help with my business evaluations
If you are looking for a $$$$ price on your home a/c unit, you will not find one. Depending on the type of system you have and the age which if you do not know, will be located on the data plate of the unit. If you have a unit outdoors and a indoor unit, they will have the name of unit, take down the model and serial numbers as the size, tonnage, and manufacture date will be in the serial number, you can find out the cost of the unit this way. Just give this information to any a/c repair company, and they can tell you pretty much the cost of the system. I hope this has been helpful to you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Ps, The more info you write down, the better off you will be, like voltage, freon type, this will all be on the data plate. Good Luck.
May 12, 2011 | Heating & Cooling
I have found this model number on the side of the AC unit outside my house and I need to know the tonnage rating. I know it is only 10 seer but can't find this info on the tag.
Did you include the make and model information?
I only see your question worded this way:
I have found this model number on the side of the AC unit outside my house and I need to know the tonnage rating. I know it is only 10 seer but can\'t find this info on the tag.
Tell us more-- or go on line and do a search for the make and model-- Can you do that?
Mack B.
Dec 28, 2010 | Heating & Cooling
Need to find tonnage of a Luxaire A/c unit serial # ECBM079879...
Get Model number of compressor (all compressors have a tag with a model number on them), and call a dealer who can tell you the tonnage of the compressor which will be the same as the unit.
Note: Write down all the numbers on the compressor to be sure you have the proper info that the dealer will need. Also, you can probably do a 'search' on the computer with the model number of the compressor to find the tonnage.
good luck!
May 03, 2010 | Heating & Cooling
I am looking for specs, specifically the RLA, on a Carrier Model 48LH006600(?)-- not sure about model #, nameplate data is totally faded!
It will tell you on the metal plate on top of the compressor, or sticker what the R.L.A.are and the L.R.A's are. If you cant read them, try and get what information you can from the compressor, like the name, Tecumseh, Copeland scroll, ect, The 48 would be the tonnage, 4 ton, or 60 a 5 ton unit. You should have enough of the model number for a air conditioning wholesale parts house to tell you this. we deal with this in the field daily.
Good Luck, Shastalaker7 I hope this helps you.
Nov 06, 2009 | Humidifiers
The motor compressor is hard to start need to apply a starting capacitor. could you help me how to tap the starting capacitor to motor compressor 1hp of air-condition
Go to AC suply house and buy a Super boost start kit. You will need to know your tonnage of your unit.Very simple to intall. Russ
Nov 06, 2009 | Refrigerators
Ruud UAKA030 Air Conditioner Logo
353 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
