Question about Sanyo DS20930 20" TV
No remote control
I need to switch the tv to us the AV jacks, but I have no remote control.
  • Dianne Meyers
    Dianne Meyers Dec 08, 2008
    My problem is similar, but I am using the av jacks, but cannot switch back to tv on the remote control. Please help me ASAP! I have an Sylvania tv with the all in one remote control.
    Champion:
  • 232 Answers
A LONG SHOUT IS A UNIVERSAL, OTHERWISE UR BEST BET IS A VCR ON CHANNEL THREE AND PLUG YOUR OTHER DEVICE INTO THE VCR.
Posted on Aug 11, 2008
Hahnel Giga T Pro II remote function not working
Hi Jack,
I assume you have an answer by now but if not. Cable between receiver and camera is the issue. One of the jacks has 3 black rings on it, which must go into the receiver. The other has 2 black rings and goes into the camera.
regards
Kent
Mar 27, 2013 | Hahnel Giga T Pro Ii Wireless Remote...
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
How do I watch a dvd movie on tv? I have the dvd
press the av or au bullon on remote until you get to the dvd "channel"
Feb 11, 2010 | GE 19GT243 19" TV
Have inherited RCA television with AV input on back, but remote and using buttons on TV allow only channels 4 and 7 to be be seen. How do you make televsion recognize AV input from back? RCA model F20600...
Bring up your video menu, make sure the cable/antenna mode is set correctly. Also do channel search/ auto program. If your AV is operating a DVD player etc., there should be a button to switch from TV to AV. If you are trying to input Cable/Antenna to AV jack you may have it plugged into wrong jack, it should go into 'antenna/cable in' jack. Hope this helps.
Nov 08, 2009 | Televison & Video
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
No TV signal
If it's hooked to Dish network, you have a receiver to connect to the TV. If you're using the receiver's RF output on channel 3 or 4 to the TV's antenna jack, you need to have the receiver on while the TV is scanning or it won't add the receiver's output channel. You can rescan channels after you turn the receiver on. If the TV has AV input jacks and you're connecting the receiver that way, you need to switch the TV to the AV input. That may be difficult or even impossible without the TV remote.
May 04, 2009 | Televison & Video
AV Jacks....
Hi! Try connecting the wires to the same colour jacks and also chekc for AV button on the remote which is sue to switch the TV between AV 1 or AV 2 mode.
Thanks
Rylee
Jan 12, 2009 | Recoton Advent Advent TS2066A TV
THE TV IS BLANK EXCEPT FOR THE LETTERS AV IN THE TOP RIGHT HAND CORNER, I CAN'T GET ANY RESPONSE WITH MY REMOTE CONTROL.
you need to take your tv out of the audio video mode (av is for when you run a game or dvd player into the jacks on the outside of your tv) the renote will have a botten to change to reg tv
Dec 06, 2008 | Televison & Video
Can't change TV to AV input.
dont bother trying to do it but then i got the same problem :)
Nov 30, 2008 | Televison & Video
Sanyo DS20930 20" TV Logo
111 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
