Question about Refrigerators
Frigidaire Middle Section is hot
I have a 2002 MOD FRS26R2AW4, which is a side-by side refrigerator. The fridge is cooling fine, but the middle section between the freezer and fridge is hot to the touch. Please assist.
SOURCE:
  • 1462 Answers
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
transom between fridge and freezer is usually haeted to stop condensation when you open freezer door. suspect you have no fault
Posted on Jul 14, 2008
docjohn174
  • 943 Answers
SOURCE: refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Posted on Oct 04, 2008
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
VtToolMan
  • 704 Answers
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Posted on Aug 03, 2009
SOURCE: My Dometic rv Refrigerator does not cool the lower
If the freezers ok, then airflow is the issue, as the reefer gets its air from the freezer, set the dial that does not operate the compressor to the middle setting, pegging it to cold, makes the freezer colder by starving the reefer!, very common call requiring no repair , just a setting change!! never peg it!!
Posted on Jul 19, 2010
My gold star three door gr403s fridge isnt staying cold in the fridge section only. the freezer is fine but the middle chiller section is also having a few issues. Im not able to replace is as Im a pe
You might check this link for details that are similar to your fridge issue. Likely you do not have cold air fanning to the bottom compartment hence not cool. I assume your seals work properly and that it is a fridge internal issue.
Refrigerator Repair Not cooling properly freezing up on the back panel...
Feb 13, 2015 | Refrigerators
Two door side by side fridge middle wall is hot ,fridge not working very well ,5 year old kenmore ,any soloution ?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | Kenmore 53642 / 53644 Side by Side...
I have a 6-2003 Frigidaire side by side Model#FRS23F4CW0 Electrolux refrigerator. It gets hot in the middle of both doors the frame only. Is that normal.
Mine did the same thing and then stopped cooling within a few weeks. I opened up the lower back cover to check the coils for dust and found that the fan had stopped working. I took a box fan and blew air through the coils and it started working just fine. Now I just need to fix the fan problem and I'm back in business. Bottom line: check under the fridge to make sure the coils are able to dissipate the heat.
Mar 09, 2010 | Frigidaire FRS23F4C Side by Side...
I have a frigidaire side by side refrig. mod frs26rlecse the evaporator fan don't work I put new one , but the new one don't work neater .the freezer side work but freeze in the bottom , and the frige...
HELLO,
This fridge may be lacking the chemical called freon, a typical coolant agent used in refrigirators, try to replace the coolant, and then let the fridge run some time. It should be back on cooling as normal...:)
Sep 09, 2009 | Frigidaire FRS3R5EMB Side by Side...
Kenmore side by side refrigerator is cold inside, but bar in the middle separating the frezzer from the fridge is hot to the touch
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. Ihad inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Aug 25, 2009 | Refrigerators
Error codes for Samsung Fridge
you need to check the refrigerator defrost sensor connection thats behid the light bulb in the middle of the refrigerator section
May 24, 2009 | Samsung RS2534 Side by Side Refrigerator
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridgerator
Oct 04, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore side by side not getting cold
check the condenser motor at back of unit if is not running it will get hot in the middle section and it wil not cool properly
Aug 06, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
