Question about Asko Dishwashers
I have just moved into a new house with an Asko Dishwasher. It is not working. I program it, the icon for the cycle I have chosen lights up in red, I press start, that lights up in red, the water runs in for about 30 seconds and then nothing more happens. This happens on every wash cycle that I attempt to use. It does not appear to be on time delay as that icon does not light up. Also I have left it for a number of hours after I have tried to start it and still nothing happens. I would appreciate your help Deirdre Lewin email address is stevelewin@optonline.net
SOURCE: Asko dishwasher problem
Hello, What you are describing is called an overfill. Sometimes programming, soap usage or installation can cause this. ASKO Customer Service will be able to give you troubleshooting tips and will most likely be able to fix this issue right over the phone as this is typically an easy fix. You can contact the ASKO Customer Care Group at 1-800-898-1879. They are open 24 hours a day, 7 days a week for your convenience. Sincerely, AM Appliance Group
Posted on May 29, 2007
Rotu
  • 175 Answers
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Posted on Nov 06, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: Kenmore Ultra Wash Dishwasher Problem
my kenmore ultra wash #665 - the start is delayed and does not pump water????
Posted on Aug 28, 2009
Is my asko d1776 repairable. It's currently not going into wash mode. The Blade are not turning and washing.
The motor is not getting switched on at the proper time. The timer / cycle selector is the problem and is easily repairable.
May 25, 2015 | Asko D1776 Stainless Steel Built-in...
Can't choose just one option like "Rinse & hold" on the control panel.
try this
turn the machine on at the wall select what you want then press the start button
it is possible that you are trying to change the program after it is started and that is causing conflict
Mar 25, 2017 | Asko D1796FI Built-in Dishwasher
Asko t702c stops working after about 5 minutes
If you continue to try to run the dryer after the automatic shut off kicks-in it will shut the cycle down with no flashing lights after the dryer reaches a critical and dangerous temperature. If the dryer is skipping immediately to this step without any flashing lights then call an Asko certified repairman as something may be wrong with the machine. If you have not tried cleaning the condensor, please do this as well. Remove the bottom housing of the dyer, move the two red handle to the right, and pull out the condensor unit. Wash it under warm/hot water using a bathtub or shower and you will see lint and dust come out by the heapful. Replace the condensor unit, wait about 30-45 minutes, and then try restarting your dry cycle.
Kevin C., Asko USA.
Jun 07, 2009 | Asko Dryers
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Mar 12, 2009 | Asko D3152XLSS Stainless Steel Built-in...
Asho D1976 Dishwasher, what do the SYMBOLS mean??!!
power button far left then heavy wash, normal ,light,and quick i think you also have economy and temp bottons.if you live in aust call 1300 00 2756 or goto www.asko.com.au hope this helps
Mar 11, 2008 | Asko D1976 Built-in Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
May 28, 2007 | Asko 1595 Dishwasher
Dishwashers Logo
32 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
