Question about Acer Aspire 3680 Laptop
HDD failure on an ACER laptop
I think my hard drive is failing it won't boot and trying to reinstall the os won't work. Do you know what HD is compatible for an acer aspire 3680-2249?
And what site I could find one on?
    Scholar:
  • 125 Answers
With the exception of interface, laptop hard drives (2.5" drives) are easily interchangeable. You can look up the specs of the drive you pull by googling the manufacturer and model number, but the main specs are interface (sata or ide, yours is ide according to the info I found about this laptop- not interchangeable with sata), drive speed (yours probably 5400 rpm, faster ones are 7200), buffer size (usually 8 MB).
So, if you think the issue is your drive, check out something like:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1277&name=2.5-Hard-Drive
although Iwould probably go to a store personally instead of any kind of mail order. Take your old drive with you if you are not sure. You could even put in a bigger capacity drive; I believe your laptop came with only 80GB??.
Posted on Aug 10, 2008
Acer won't restore
It sounds like you have a HDD fault, Your hard drive has become faulty or damaged. Has your Acer been dropped or banged? The lid slammed shut?
If you have tried to reinstall your OS and failed, its definately a HDD fault.
Feb 26, 2013 | Acer Aspire 5742G
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
It won't finish loading the OS - it says bakup the HD its about to die! How do I back up without OS? I think the HD is toast. Is it worth replacing this -what is the cost?
The HDD has probably tripped a SMART sensor and is dying.
Remove the HDD and replace it (usual cost on newegg is $50-150).Reinstall the OS to the new HDD.Use an external enclosure to use the old HDD as an external and recover the data from it.
Jul 27, 2011 | Acer Aspire 5100 Notebook
My sony vaio pcg-551l won't go past "no operating system"
If this is the first time your trying to start up this computer try to restart it. Sometimes brand new laptops can fail to find the operating system on first startup. If this isn't the case it sounds like your Hard Drive is either disconnected or has had a critical failure.
Mar 15, 2011 | Computers & Internet
PXE-E61 media failure when i start up my computer
The PXE-E61 failure is a failure to boot to the network card, this generally indicates a problem with the hard disk drive.
  1. Boot to the BIOS and reset the defaults
  2. Reseat the hard drive
  3. Boot to Windows CD and run CHKDSK /R on HDD
If the system will not boot to the HDD, but it is seen in BIOS, then the HDD may have an OS issue, if not detected in BIOS HDD likely has failed.
Mar 02, 2010 | Acer Aspire 5315 Notebook
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
Reinstalling
Hard drive has bad sectors on it which is why its giving you that message even though you can go thru the restore. Normally going thru the system cd and then the recovery cd should bring you into windows with the device drivers installed.
Dec 10, 2009 | Acer Aspire 5520-5156 Laptop
Acer 5620-6266 notebook will not boot--Media Test failure
Open BIOS and configure your boot devices priority. First boot device should be the hdd. Also check if the laptops see the hard disk, i think your hard disk have a problem and thats why laptop wants to boot from network.
Jul 18, 2009 | Acer Extensa 5620 Notebook PC
Blank screen
can you obtain a linux dsl stick / cd - This will help bypass your HD
Do you have floppy drive - if so..can you create a DOS boot disk
try and boot from another media - this will rule out Hard drive / os failure, and focus on the laptop itself.
If this fails - it would appear to be the video driver... let me know from here on..
Aug 06, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire laptop
Hi
OS means operating System and HDD stands for Hard Disk Drive.
When u turn ur system on is it already black or it shows the bootscreen like ACER logo etc. and then goes black.
If thats the case then ur OS has crashed. Try installing new one.
And if its black right from the start then i think it is a hardware failure.
In any case let me know.
Jun 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3680 Laptop Logo
117 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
