I have an Emachine and the disk drive won't work a box pops up and says at the top RunDLL and inside it says Error loading C:Windows/system32/gzmrotate.dll
    Novelist:
    Scholar:
  • 141 Answers
RunDll is a system file. Error loading C:Windows/System32 is also system files. Just do a repair---not a recovery. The repair option is after you have to hit F8 then choose "R" for repair. This should take care of it. If not it may be your hard drive in which case you would replace it and have to do a full reinstall.
Posted on Aug 10, 2008
Everytime I start up Windows I an error message.
Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
I have a box that displays when I reboot my Emachine,
If the DLL is necessary for playing games like Pokerstars or using Skype, I would consider reinstalling both.
If you don't know what it is, I would run a quick antivirus scan to see what comes up. Dll files can be nasty, but in your case I believe it's a simple missplacement of the required file to run certain streamed services (such as in your example - Skype or Pokerstars).
Mar 18, 2010 | Computers & Internet
Whenever we try to load a game disk a error
The first step is to check the disc. If you are sure this is not aproblem with the game disc, then this is usually a problemwith either the laser inside of the Wii's drive, or some other issuegoing on inside of the DVD drive. The following website sells the DVD drive mechanisms and does repairs on the Wii as well:
http://store.richspsxparts.com/wiiredvddr.html
Nov 17, 2009 | Nintendo Wii Console
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
Every time I start the computer, the computer pop
A rundll error can often be fix by simply using a good Registry Cleaner. Click here to use a free scan to find and repair the problem.
Like...
http://www.ccleaner.com/
Thanks
Kindly rate the answer
Smith
Jul 09, 2009 | Computers & Internet
RUNDLL
The first thing you must do is to identify the specific rundll process. This is not a difficult task; there is a vast online process library in which you can evaluate the validity of the process that is running. When the error dialog box opens make not of the process name. For example if the dialog pops up and shows you the dll error:
Error loading C:WINDOWS\ system32\ usvdgpo.dll
Visit www.processlibrary.com. Copy and Paste the dll or simply type it into the search box. The results will indicate that the program is a part of trojan spyware.
STEP 2: STOP THE PROCESS
Often you can locate the Run Dll in the exe services. You can open up your services configuration by following instructions below:
1. Open your Start menu.
2. Click Run
3. In the command screen type:services.msc
4. This will bring up the Services Management window. If you drag the mouse to one of the services. It will give you a detailed explanation of the service in question. By right clicking the individual service.
5.Stop the "dll"service immediately.
STEP 3: LOCATE AND DELETE
You will have to open your Windows Registry File System. This is an extremely delicate process. You may want to use a good registry cleanerThis will often fix the dll error in question, eliminate other errors and also speed up your computer. The registry key: HKEY_LOCAL_MACHINE> SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ RUN
This action will help you speed up your applications load times considerable. Here is how:
1. Click Start
2. Click Run
3. Type regedit
4. Find this registry key:
5. In the right section click:"rusvdgpo" = "%System%undll32.exe %System%usvdgpo.dll, [RANDOM LETTERS]"
6. Delete the value and Restart.
May 01, 2009 | Computers & Internet
I get pop up blockers on my computer every time i turn it on.
you have virus (melware) on your machine. do you have any type of anti-virus program on the machine/ if so, please run it. if not, go to vga.com and download the antivirus software, and run it.
Apr 08, 2009 | HP DeskJet 3000 Printer
When I log on the internet this pop-up shows up.
You may have downloaded an Internet Explorer Toolbar, and it is not working properly.
It's called MyWebSearch, you might see it just under the address bar on Internet Explorer
Double Click Programs and Features icon in the Control Panel (in Classic View) and Uninstall MyWebSearch.
Also, in Control Panel, double click on Internet Options. Then click the Programs Tab at the top of the box that opens. Then click the Manage Add-Ons button.
Look for MyWebSearch in the list in the Window that pops up and disable it by left clicking on MyWebSearch to highlight it then clicking the Disable button below the list.
Hope this helps, let me know if it fixes the error.
Apr 08, 2009 | Microsoft Windows Vista Ultimate Edition
In start up RunnDLL pops up saying ERROR (please help)
this problem is due to missing of dll file from your system, click on Start> Run, type msconfig> tab startup from top and find out the file name above which you just mention and uncheck it now click apply and Ok after restart you will get some messege check mark on it.
Mar 29, 2009 | Microsoft Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
