Question about Brother P-Touch 1180 Label Printer
Brother PT-85 Our label maker does not print or feed the label. just about 1/2 inch comes out when you print & it only has a line - nothing that we had typed for the label.
  • dolphinlady Aug 24, 2008
    I have the same problem. I changed the batteries to fresh out of the package newly purchased ones and it did not help.
  • Anonymous Feb 09, 2009
    I'm so sad. I love my label maker... it looks like it's now dying. I get the same little random two lines or a colon instead of my word.
  • 114 Answers
Make sure you have fresh batteries, It sounds like the batteries are low,
Lou
Posted on Aug 10, 2008
    New Friend:
This happened to me after a battery change, only printing an "I"
Change of batteries didn't help BUT .... A change of batteries AND a reset (Switch on with Code and Clear depressed) fixed it!
See Manual Care & Precautions 9) ....
Posted on May 08, 2016
When I try to print with my Brother PT-1200 label maker, it says "ERR" and does nothing. I changed batteries and the label cartridge but still nothing.
open the back of the label maker. remove the cartridge. in the lower right hand corner of the where the cartridge fits, there are 3 little posts that are pushed in when you insert the cartridge. find the holes on the cartridge that fit over those posts. cover the holes on the cartridge with tape. reinsert cartridge. try again. worked for me. If you push in the posts individually, you can figure out which one is giving you the error message. I'm not sure that it really makes a difference. I taped over all three holes and it worked fine after that. i realize its not a perfect fix, but may allow you to print anyways!
Jun 08, 2011 | Brother P-Touch PT-1200 Label Printer
I have an "old" p
When labels print i get back ground i do not want
Mar 04, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Brother P-Touch 1200 label printer doesn't feed whole label
Take out your cartridge and look at the end of the tape, it should be under the guide, the skinny bar, before going into your machine. Make sure you tuck it in under that bar and it should be OK.
Aug 28, 2009 | Brother P-Touch PT-1200 Label Printer
How and where do I feed new labels
press and hold the code button and press the "space button" this will feed the tape
Feb 18, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Need help loading cartridge for brother label maker
when you have the label maker upside down...
place the cartridge so the WHITE 12mm ect sign is on top.
pull the tape out a bit and pull it up so that it stick out where the tape would print out of.
place the cover back on tightly and turn on..
push CODE, SPACE, it will feed though and you'll be all set.
Dec 08, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Ptouch weak printing
You need to take a q-tip dipped in alcohol and clean the printhead. Let me know if this helps.
Lou
Sep 09, 2008 | Brother P-Touch 1180 Label Printer
Brother P-Touch 1180 Label Printer Logo
1,019 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
