Question about Panasonic KV S2026C Path-Through Scanner
Resetting the counters, when you don't have the original product's disk
How do I reset the counters for my Panasonic KV-S2026C when I have lost the original product disk? The Panasonic web site says, sorry, we only provide a disk with the original equipment. I feel that is a really bad policy. Any suggestions? Can anyone e-mail me a copy of their original equipment disk? joseph.diehl@gmail.com
  • Joseph Diehl Dec 06, 2008
    Well, I finally "junked" my scanner before reading your solution. Maybe I'll haul it out of the garage and give it another chance. I was told by the person I bought it from, that it needs new rollers and then it will be good to go. I hesitate investing money into this machine. Thanks again for your solution.
    Problem Solver:
  • 16 Answers
You can download the User Utility from this page: http://panasonic.co.jp/pcc/products/en/scanner/downl_e.htm#USERUTY
The utility will let you reset the Clean Roller counter.
Posted on Dec 02, 2008
Kv-s2026c paper jam
Are you just receiving paper jam message or paper is actually jammed in the unit.Or the paper is getting jammed every-time while getting the printout.Click this link below :-----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 26, 2012 | Panasonic KV-S2026C Pass-Through Scanner
I have a Panasonic Scanner KV-S2026C I NEED A SHADING UTILITY DOWLOAD CAN YOU HELP
You can find everything you will ever need for this scanner at the link below
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=67997&catGroupId=13858&surfModel=KV-S2026C&displayTab=R
May 14, 2011 | Computers & Internet
Red Light on and software says its got paper in the feeder which it doesnt.
Dust on the paper sensors is a common problem with ADF scanners such as this. Look at the paper sensor video on our web site for hints
MyEfact
Dec 17, 2010 | Panasonic KV S2026C Path-Through Scanner
Red light continues to flash
Just You can see a Reset Option in your Device just use that Device Then your Problem will be Solved
Please Rate My answer
Aug 12, 2010 | Panasonic KV S2026C Path-Through Scanner
How do you reset the counter on a Panasonic KV-S1025C. I have cleaned all of the wheels but can not find how to reset the counter. Many Thanks. Mike.
Click on the Scanner user Utility at the bottom of the pc task bar it is a yellow box it has a button inside to clear the counter
Dec 10, 2009 | Panasonic KV-S1025C
Error Message: Rollers dirty; Clean rollers; Push 'Reset Counter'
There's a user utility that installs with the driver & other software. The counters for cleaning & replacement are in that.
Apr 09, 2009 | Panasonic KV-S2046C Pass-Through Scanner
Yellow light is blinking and error indicates clean rollers. Rollers have been cleaned but message keeps coming back. No problems scanning.
Panasonic includes a user utility with this model. The utility can be accessed via Start>All Programs>Panasonic. In it you will find a display and reset function for the cleaning count. Sorry I don't have more specifics, its been a while since I worked on any Panasonics.
Apr 06, 2009 | Panasonic KV S2026C Path-Through Scanner
Roller fell of on the inside of panasonic kv-s2026c
yes normal. thier are 2 black rollers. they are spring loaded so when the door is closed the correct tension is applied to them.
Bboss
May 15, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Remove paper from scanner
I have this same problem every time I unplug my Panasonic KV-2026C. I've lost the original disk with the utilities, and the Panasonic web site says, they only provide the disk with the original equipment. You know, I'll never buy another Panasonic product. But I'm usually able to get the ready light to come back on by doing the following. I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish remover, but pure rubbing alcohol). I basically open up the back, and clean each roller. There are two green tabs at the top of the back of the scanner. These need to be opened up (be careful, because the parts sort of fall out if you're not careful, and they are difficult to re-assemble). Again, wipe everything down with the rubbing alcohol. Close up the upper tabs. Make sure you wipe down the glass slits on both the door (front-of-the-page scanning port) and on the unit itsel (back-of-the-page scanning port). Before you close up the back door, let it sit for about 5 minutes, allowing the rubbing alcohol to evaporate. I also connect the scanner to the laptop and get the "blip" sound from Windows to recognize the scanner. I don't know if that's important or not. Then I say a healthy prayer, plug it back in and shut the back door. If there is a god on duty that day, the ready light comes on, and stays on as long as I have the power connected. I just went through the process and it worked!!!! The minute the power is off, the error light stays on. Good luck, my friends! Joe Diehl, Seattle WA
Dec 04, 2007 | Panasonic KV S2026C Path-Through Scanner
Panasonic KV S2026C Path-Through Scanner Logo
973 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
