Question about ASUS M2N-MX Motherboard
SYSTEM ERROR I have found an error in my computer. When I am switching on power button of my computer following messege is appearing :- "Auto detecting USB mass storage devices ... 00 USB mass storage devices found and configured. USB device over current status ditected !! System will shutdown after 15 seconds." After showing the above message the computer shutting down after 15 seconds. Even I cannot enter in BIOS setup. I have checked all the hardware & USB port but the result is same. If anybody help me i will very gratefull to him.
  • 781 Answers
1) if you have nothing in a USB port you will need to set bios
Try removing M/board battery for 2 to 3 hours some people say less then replace it most times it should set BIOS back to default
also check setup of hard disks master slave etc
Last resort with 15 seconds you should be able to see
press ?? key to access BIOS next boot keep pressing key see if that works
Posted on Aug 10, 2008
4 Suggested Answers
  • 508 Answers
SOURCE: System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
Posted on May 31, 2010
Hanto
  • 226 Answers
SOURCE: bios setup error
Unplug ALL Usb devices, that includes printers, cameras, pen drives, i.e. anything that plugs into a USB connector. Then try rebooting your computer. I bet your problem will no longer exist, but if it does, then you need to suspect a faulty USB connector on the motherboard or USB chipset located on the motherboard. Once the computer is booting normally without USB devices hooked up, you can start installing ONE Usb device at a time, until you find your defective USB device. The USB device drivers will need to be installed and computer rebooted at least once between the various devices. Not doing so will lead to confusion as to which USB device is causing your high current problem. It is also possible athough a bit unlikely that this procedure will cure your situation for the time being but look out for it in the future because it could be an early sign that one of your USB devices is going bad.
Posted on Aug 12, 2008
  • 42 Answers
SOURCE: system shutdown in 15 seconds
hi, pl check for viruses, scan the system, and go to cmd prompt and issue this commnd at c:\ shudown -a and press enter to disable reboot and scan the system and check any hardware issue.
Konica minolta bizhub c253,how to reset transferbelt by using fusser
There are two ways to reset an error code:
  • 1. Open the front cover, wait for a few seconds and then close it. If the error is still there try the second method.
  • 2. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.Restart it normally and it should work. If the error is still there, try to follow the steps provided in the solution found based on your error code.
Aug 21, 2014 | Office Equipment & Supplies
Tip
How to format Nokia N72, N73, N80, N81, N95, NSeries Phones
<span> <p>Nokia Became the Most Admired Mobile Phone Manufacturer and Most of the World mobile phone users have <a href="http://www.messiphone.com/mobile-secret/nokia.html">Nokia phones</a><br />But some models are more popular than others like N72, N73, N80, N81, <a href="http://www.messiphone.com/mobile-secret/nokia-n95.html">N95</a> and NSeries. <br />To fix some problems ( eg : get infected with virus, some system errors or installed too much software on it), many users asking me how to format Nokia NSeries Phone</b>.<br /> <p>So here are 3 ways method to format your Nokia NSeries cell phones<br /> <p><br /> <p><span> <p>Method 1<br /> <p>1. Turn off the mobile Phone.<br />2. Press and Hold the following three buttons: Green Call Answer button</b> + the "*" button</b> + number "3&prime; button</b>.<br />3. While holding these buttons, press the power button</b> and switch on the phone.</b><br />4. When the message 'Formatting</b>' appears on the screen, release all of the buttons</b>.<br /> <p>Method 2<br /> <p>1. Switch off your Noki</b>a mobile phone<br />2. Now Press following key sequence *#7370#</b><br />3. Enter Default lock code is 12345</b>.<br />4. While holding these buttons, press the power button</b> and switch on the phone</b>.<br />5. Wait for message 'Formatting</b>' to appear on the screen and release all keys once you see that message.<br /> <p><span> <p>Method 3<br /> <p>1. Switch off</b> the phone.<br />2. Hold down *#7780#</b> button.<br />3. While holding these buttons, press the power button</b> and switch on the phone</b>.<br />4. When the message 'Formatting</b>' appears on the screen, release all of the buttons.<br /></span><br /></span><br /></span>
on Jan 11, 2011 | Nokia N73 Cellular Phone
Close side cover error tray
You see front cover switch if front cover knob not touch then this messege appear OR check power card & front cover connection
Nov 06, 2013 | Toshiba e-Studio 350 Copier
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
May 31, 2010 | ASUS P5PE-VM Motherboard
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Bios setup error
check your c-mose battery when power cable is unplugged the battery remove and after few seconds battery fix them and connect power cable then on the computer
Oct 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Aug 12, 2008 | ASUS P5PE-VM Motherboard
Bios setup error
Aug 11, 2008 | ASUS P5PE-VM Motherboard
ASUS M2N-MX Motherboard Logo
532 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
