Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Timer on stove buzzig cannot shut it off - GE Profile Spectra JGBP90 Gas Kitchen Range
Timer won't stop buzzing
Posted on Apr 10, 2009
SOURCE:
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Timer keeps going off
push in timmer knob turn till its at 12 o clock if it does not shut off then the timmer is bad ..you can dissconnect timmer from the back ..turn off breaker or unplugg. dissconnect wires from timmer .. tape connectors real good .now no annoying buzz
Aug 22, 2010 | General Electric Stove/Oven/Range Chrome...
The beeper on the stove timer came on for no reason at all, and I cannot get it to shut off for good. If I press timer, it will reset back to 1 hour and 59 minutes, but when it goes back to zero, the...
I would inspect the circuit board closely for a shorted component. If visually it appears normal it is likely the control board will have to be replaced. Eric
Aug 18, 2010 | Ovens
I want to turn off the clock on the stove
i want to turn off the clock on my whirlpool stove
Jan 06, 2010 | General Electric Stove/Oven/Range Chrome...
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Replaced the old element in the stove now the stove wont turn on
Check the wires going to the broiler and see if your getting power there.
Oct 03, 2009 | General Electric Stove/Oven/Range Chrome...
I get a buzzig sound from the bottom of the
Does it have an ice maker that is not working? The only thing I can imagine it could be is the start relay, condenser fan blades hitting something in its way or the water control valve trying to open because the ice maker is telling the water valve to open. Double check the model number above your post so I will pull up the correct manual for your refrigerator. Thanks, Sea Breeze
Apr 21, 2009 | Amana AFD2535DES French Door Refrigerator
Oven wont turn on and f7 keeps beeping, but stove top burners work on ge spectra xl44 on model number jgbp86bea3bb
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
Thanks
Mar 07, 2009 | General Electric Stove/Oven/Range Chrome...
Code F7 appeared during oven use
You have/had a stuck keypad. If it happens again just push all pads at random to try and unstick it. If it gets to be a nuisance replace the keypad membrane.
Jan 30, 2009 | Maytag MER5530 Electric Kitchen Range
Amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Nov 16, 2008 | Amana Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
511 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
