Question about Universal Remote Control Remote Control
Universal remote i have an old universal remote i need to program for my tv (Model Sharpe) the numbers on the battery cover are xx153038/xx152647 help!
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
reprograming ilo tv
Posted on May 15, 2008
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
SOURCE: getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Posted on Feb 07, 2009
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
SOURCE: I NEED CODES TO MY WIRLESS CEILING FAN REMOTE
What codes? There are 4 dip switches (see DIP switch wikipedia) inside the remote control and 4 inside the sensor that is inside the fan. They have to be in the same position. If you don't feel like messing with the one inside the fan, keep changing the ones inside the remote. U= Up, D = Down
U-U-U-U, U-U-U-D, U-U-D-U, U-D-U-U, D-U-U-U, U-U-D-D, U-D-U-D, ... D-D-D-D (*There are 16 possible arrangements*) On e of these arrangements will work (has to work) if the remote components are not damaged.
Posted on Dec 22, 2009
Programming my digital remote to my tv
u take the cover off where the batteries are and there should be a sticker inside with the model of controller, then just use google and type something like "brand and model number of remote " "programming codes and instructions" then filter through the results.
Jul 01, 2016 | RCA Universal Tv Digital Converter Box...
I NEED THE CODES NUMBERS TO PROGRAM THIS TV WITH UNIVERSAL CONTROL
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
Make a note of which version you have and replace the batteries and cover. A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Programyour GE Universal Remote using the correct code list and instructions. ... Sometimes a code will allow limited function control (e.g. volume and channel ...
Universal Remote Control Codes
www.remotecodelist.com/
Codes and links for a number of universal remote controls, including Sony, RCA, ... If you have a remote for which you know the codes (or a web page that lists them) head to ... How to Program a GE Universal Remote Control .... look for your model of TV or VCR and find the online instructions that include the remote codes.
RCA Universal Remote Control- Target Programming ...
Jan 05, 2016 | Coby TF-TV3217 32 in. LCD TV
Prgram old RCA removte
I also have an early RCA universal remote with the number 97P04730 stamped on the battery cover. I do know if that is the part number for the remote. There are buttons labelled TV and VCR, presumably to select which device the buttons will work for. This remote has a "search" button, but no "code search" button that is found on later RCA remotes. I have spend several hours searching the net for any information on this device. The only thing I found was a post that claimed this early remote is programmed by pressing and holding the device button (TV or VCR) and simultaneously entering the device code. Because this is a very old remote, it probably uses 3 digit codes. There are several places that list RCA 3 digit remote codes. I have tried to program mine this way, but I have not been successful. Possibly my remote is not working correctly, but it is putting out IR.
Jan 29, 2012 | RCA Universal Remote Control
Where do I get a code number to program a universal remote????
Universal remote codes differ among remote and TV manufacturers. For codes specific to your remote, you should search Google with the model of your remote (usually found on the back of the remote or under the battery cover) and words like "remote control".
Mar 05, 2011 | Televison & Video
Universal remote has lost it programming and wil not operate tv. I need codes and to know how to enter them into the remote.The tv is a SylvaniaModel 6424TF Please respond. Thanks you Pauline
Hi, I have a few things for you to try.
1. Your TV "6424TF" seems to have problems with its IR "Infra-red" sensor going bad. This is a common problem with your model TV. If this is the case no remotes will work on your TV.
2. Because I do not know the model of your universal RCA remote I cannot tell you how to program it.. please supply the model number of it. Try looking under the battery cover. might be an "RCR..." number. I need to know this because all universal remotes have different codes and programming methods.
3. To know 100% if its your TV that's bad you will need the original remote for your TV. I have already looked up your original remote and you can purchase a brand new replacement that will work right out of the package (assuming your TV IR sensor isn't broke) here: RR0108UD for all sylvania TVs . no programming is necessary for this remote.
Aug 11, 2010 | RCA Universal Remote Control
I have a universal remote and need a code to program it to a tv
in the battery compartment, usually on the cover is a 800 number to call for codes
Mar 06, 2010 | General Electric Universal Remote Control
Where do I find the model number of the universal
I would try looking on the inside of the battery cover. Sometimes universal remotes will have a sticker in there or it will be printed directly on the inside of the battery cover.
Jul 05, 2009 | Televison & Video
Jun 03, 2009 | RCA Universal Remote Control
Need code for remote. New remote needs replacing.
Cable and Satellite content providers control the remote codes,
and we apologize for any confusion during the remote programming.
Please try the following codes 10019, 0178, 10178, 0030, 10030,
0835, 10835, or for Dish Network try 627, 659 or 505. For Fios
TV (Verizon), try the code 3264. These codes may not work on some
universal remotes. If there is another code listed for Element
Electronics in your universal remote control guide, please try that
code. Refer to the Remote Control Guide under your TV’s model
number for more information.
May 09, 2009 | Element ELC-HS321 32 in. LCD TV
I need the code to program a magnavox remote to a RCA tv
A magnavox remote should program like the phillips universal. I will post the link. If this doesnt help post the model number of the magnavox remote that you are trying to program. the model number is usually in the battery compartment.
http://www.universal-remote.net/philipsmagnavox.html
Feb 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Universal Remote Control Remote Control Logo
139 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
