Question about Samsung SCH-u740 Cellular Phone
Directional keys the scroll and directional key pad wnt wrk
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile repair shop and have them fix it for you
Posted on Sep 20, 2008
SOURCE:
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
The scroll pad doesn't work
Hi, Inorder to get the scroll pad to work you need to press and hold down the Fn key located on the bottom row of the keyboard and with the Fn key held down push and let go off the F7 key and should be able to get the scroll pad to work. Thank you for your patience and best wishes for your effort.
Jan 04, 2011 | Acer Aspire AS5520-5537 Notebook
I would convert an french my samsung e250
Follow this steps,
1. Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
  1. 2.Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
    3. Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
    4. Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
    5. Scroll to the language you want and press the "OK" button.
    6. Highlight the "Input language" field and press the "Change" soft key. Scroll to the language you want and press the "OK" button.
    7.Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
Nov 23, 2010 | Samsung SGHE250i Cell Phone
How do i turn off the annoying key pad beeps when writing text messages or scrolling through
There are two buttons on the left side of the phone. Repeat push a button to directly increase/decrease Key volume.
Apr 16, 2010 | Samsung B2100 Cell Phone
Its touch buttons are not working, specially the back button. plz help me.
hai thats not a key pad ic problem thats only ur mobile finising problem . do u wnt help come to my service center my number is 9942258064 , it is the small problem dont change ur key pad ic
Mar 06, 2010 | Sony Ericsson K850i Mobile Phone
I have problems typing text messages, the 7 button doesnt wrk...
it happing because c 902 has sticky button the key pad stick with double tape that`s why they stuck some times. try to change the key pad
Dec 15, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
902 wnt turn on bt lights activate
make key pad lights light up (turn on) and leave it like that mine dus it then turns on after 30 secs ,,,,my speaker wen i play music distorts wen turned over half way could you solve this. thanks
hope it helps
Aug 26, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Ink waste absorber is full, what do i do!!!
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to “Service menu counter access”.
Press OK.
Use arrow keys to scroll to “ABS-M DOT COUNT”
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Mar 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Screen broken
From main screen:
Either 'a':
Press 'down' on your directional pad to open up the phonebook (default setting)
OR
Press the menu key and scroll down to the phonebook entry (I'm not sure if you remember where yours is, as I changed my menu around. My phonebook listing is the first one. Dunno if this helps at all)
Then, once you are viewing your contacts:
Press the menu key.
Press 'down' on the directional pad eleven (11) times to highlight 'copy'.
Press the center of the directional pad in to select the highlighted menu item.
Press down on the directional pad once to highlight the 'all to SIM' option.
Press the center of the directional pad in to select the highlighted menu item (MERGE)
OR
Press down on the directional pad once to highlight the 'OVERWRITE' option, and then press the center of the directional pad in to select the highlighted menu item.
Depending on how many contacts you have, this will take about 30 seconds per 100 contacts.
Jan 04, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Samsung SCH-u740 Cellular Phone Logo
35 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
