Anonymous Posted on Apr 24, 2011
I connected my LG Mini Home Theater MDD112(Audio/Video) Player to my TV to use the AUX feature with a cable. It worked fine until my brother connected a ps2 slim to the TV. Now my LG displays "AV1 COAX" instead of "AUX" when I press the AUX button on the LG remote. Sound doesn't come out under this mode except on DVD and Tuner/Band modes. Do I need to reset it or what? Pls help
Anonymous
Level 2:
Guru:
  • Expert 300 Answers
  • Posted on Apr 25, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
300
Questions
0
Helped
52852
Points
940
  • 5 more comments
  • Anonymous Apr 25, 2011
    Pls how do I do that, I have tried all the buttons on the remote but nothing.
    try using buttons with out remote
    I have tried using the button on the deck but nothing
  • Anonymous Apr 26, 2011
    I thik it have problem with ic
    I don't think I can do this by myself. I will need to take it to an electrician then. But if there's a way I can reset it I will appreciate
    try to reset.it does not work then take to electrician.please rate me
    If you are familiar with LG Audio products, pls how do I reset it.
1helpful
Why can't I get picture or sound when my Sound Bar, TV and Blu-ray player are connected?
You have to run an audio cable from the TV to the sounder and put the sounder on the TV input for sound to work. The first choice audio cable for best sound would be optical cable if your tv has optical output on it. If it does then you would put the sounder on the din input for sound when watching antenna or any hdmi source connected directly to tv. If your TV only as analog rca out or mini audio out then put sounder on aux input. I think your sounder came with mini to mini stereo cable. If your TV doesn't have mini audio out the get a optical cable or you can find a mini to rca red/white will work. Optical is your BEST connection and soundbar would stay on din all the time for best sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
tip
Home Theater / Surround Sound Receiver simple Connection.
Are you tired of trying to remember what input on the Home Theater / Surround Sound Receiver goes with the Input on the TV? Wife fussing at you that the TV is too confusing? Here is a simple way to set up your connections.<br /><br /> <ol> <li>Connect each of your devices ( ie. Cable box, Game Sytem, VCR, ETC) to the inputs on your TV.</li> <li>Locate the AUDIO OUT on the back of the TV.</li> <li>Connect a cable from the AUDIO OUT on the TV to the TV/AUX INPUT on the back of the Home Theater.</li> <li>If the Home Theater has a DVD player built in then connect the Video out (either Component or HDMI or standard Video out) to the TV.</li> <li>When not watching a DVD (if equipped), keep the Home Theater tuned to AUX/TV for the source.</li></ol>The advantage of this set up is that whatever input you tune the TV to will then play through the Home Theater speakers without having to change the source on the Home Theater.<br /><br /><span style="font-weight: bold;"><span style="font-style: italic;">NOTE: Turn the volume all the way down on the TV to avoid distortion due to the slight delay between the TV and Home Theater Audio.<br /><br /></span></span> Hope this tip is helpful for many of you.<br />Robert<br />
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
6helpful
2answers
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
2answers
How do connect a digital cable box to Home Theater system so you can get the audio from cable through the Home Theater?
Audio out from the cable bos to audio in to the home theater using rca cables. You may choose video, aux input etc on the home theater. Just select the one that the cable box is connected to.
2helpful
How can i listen the tv sound on the home conema? I connected by hdmi cable. tks
You have to connect audio cables (red & white or optical) from your TV's AUDIO OUT to the Home Theater's AUX IN 2 (below VIDEO IN).
Press AUX on the remote control until it says AUX 2. (This would be D. IN when you're using an optical cable)
Will play dvds with sound fine...but no sound from tv
You have to connect extra red & white audio cable from your TV's (or cable box, if you have one) AUDIO OUT to the Home Theater's AUX IN 2 at the back (below Video In). Set the HTS unit to AUX 2 using the AUX button on the remote control and you should be able to get sound.
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
4helpful
3answers
Samsung ht-z310 home theatre audio problem
All,
I submitted an earlier request trying to determine why surround sound wasn't coming through all speakers when playing my TV.
Looking further into the Samsung site I found out that you MUST connect the optical cable from the home theater unit to the CABLE BOX and not to your TV to get surround sound...I'm currently in the office but will change the connection once home...try connecting to your CABLE BOX instead of your TV and it should resolve the problem.
2answers
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
