Convetgence adjustment problem - Televison & Video
  • 8,617 Answers
Please respond to this same post with your model number of your TV and I will help you with your problem.
Posted on Aug 10, 2008
Can you adjust the green in the convergence grid?
you can not get to adjust the green since it was the guide only the two color can be adjust.
Nov 13, 2012 | Televison & Video
How to fix the convergence on a toshiba TP55D81 tv using the remote control
The convergence is adjusted with the remote by entering a tech menu and adjusting there====if convergence is really bad adjustments are not going to fix it.
The set should have in customer menu a limited convergence adjustment with up to nine points where you can adjust---if it will not adjust there in some way----convergence circuit needs repair.
Mar 16, 2012 | Toshiba TP55F80/81 55" Rear Projection...
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
Adjusting color, picture & brightmess from remote contrrol
Under setup on the menu selection, The OPC must bo on the off mode, to be able to access those adjustments found under the video adjustments.
Jan 10, 2009 | Sharp 64LHP4000 64" Rear Projection...
Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence Problem and Contrast Adjustment
Have you checked all of the resistors inthe convergence circuit as well? If not, check them for the correct impedance.. Remember, you have to pull one side of the resistor out of circuit to measure it correctly.
If all of the resistors are good, then you have to do a coarse convergence adjustment on the set through the service menu.. if you need the service manual for the convergence directions, I have one uploaded in the technicians corner of techlore.com
Dec 25, 2008 | Televison & Video
Toshiba tv-model tz55v61
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
Overscan
For Factory Menu, press MENU 1 3 7 0
Service Adjustment Mode, press MENU 2 3 5 7
Convergence Mode, press MENU 2 3 5 9
Use the VIDEO or VIDEO buttons to enter two different groups of adjustments
Use the VIDEO / VIDEO buttons to toggle thru the adjustments
Use the + and - keys to adjust
When finished with adjustments, press ENTER to save
Press MENU twice to exit service mode
Hope this helps. You should look for the vertical height or size adjustment. Do not adjust anything you don't know about.
Dec 28, 2007 | Mitsubishi WS-65313 65" Rear Projection...
HC R4755w Convergence adjustment
from the symptoms you describe it would apear that maybe one of your amps might be bad... However since you can move it one way then it might be a resistor bad. in convergence cuircit that would be my first choice.
Dec 21, 2007 | Samsung HC-R4755W 47" HDTV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
