Problem with Chainsaws
I have inherited a Black
I have inherited a Black and Decker whipper snipper model WS400 and need instructions on how to replace the line
Chainsaws Logo
163 people viewed this problem
  • 2 people found this problem to be helpful.
  • 2 people are following this problem.
More Insights on Fixboard
4 Suggested Solutions Relevant solutions from other related problems that we feel might be a fix.
Author image
50:1
Farmerbear
Testimonial: "Thanks for the info. I've been trying to get the right mix for ages."
Source: i have a petrol black
  • Was this solution helpful? Yes No
Author image
  • Joe Hogan
  • 10865 Solutions
  • February 14, 2011
hello possum...
First, remove the spool from the head by stopping the engine and cutting attachment first. Then, grasp the body and insert your thumb into the tab on the head, then rotate around and press on the second tab. After this, press down on the spool and release it from the housing. Now, remove the star nut. Here is a video showing the steps http://www.wonderhowto.com/how-to-replace-line-stihl-trimmer-head-264449/ Joe Thanks for choosing Fixya!
Source: How do you replace the
Author image
I had the same problem, the black knob on the bottom just slips round not unscrewing the bolt inside. I had to lever the knob off and then undo the bolt with a spanner. The re-threading instructions are in this manual : http://manuals.homelite.com/documents/2588
Source: homelite hlt25cs centre of line
Author image
ok, looks that this is an electric trimmer or saw. this is not recomendable that you replace it because is a Double Insulated product and to replaced after repair it has to be tested so it will not shock you. I do not recommend you do it. take it to a service center or if is cheaper get a new one.
Source: I do not have a
Add your solution
Full Name
Top Chainsaws Experts
dontbother10
  • Solutions: 2220
  • Level: 3
  • Achievements: 1
drallim
  • Solutions: 4088
  • Level: 3
  • Achievements: 1
Andrew White
  • Solutions: 2034
  • Level: 3
  • Achievements: 2
Expert Badge
Are you a Chainsaw Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More Chainsaws Related Problems
Unsolved Problems:
Loading... Loading...
