Question about Pioneer AVIC-N1 Car DVD Player
Disassemble The cable from the Hide away unit snapped the yellow plug right out of the back how can I fix it? How do I take the deck apart to Solder it back on? Is this possible?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
This is very difficult to do and most electronics service centers will even recommend sending the unit to Pioneer. You'll not only have to remove the outer case from the hide away unit, but you'll need to take out the main circuit board as well. You may also be able to find someone selling just the hide away unit on ebay too.
Posted on Aug 10, 2008
How can I disassemble an unidentified tape deck?
What is the brand and model of unit? Details can not be given without this information.
Feb 06, 2016 | Audio Players & Recorders
My tape decks buzz but when i touch it with my bare finger it goes away
It can be a bad ground inside the deck or broken solder joint. I have fixed this case often but can not tell you exactly the problem unless I see the unit.
Feb 15, 2014 | Technics RS-TR272 Single Cassette Deck
Hi, the battery cable end that connects to the hummer broke. The wires snapped due to the kids pulling it apart. Can I solder it back on or do I need to buy a whole new cable. Just replaced the...
You can probably go on amazon.com and purchase another cable far less than what the stores charge. There is a chance if you solder the wires back together that it can blow the charger completely. Cutting corners is fun, but not when it comes to electronics.
Oct 14, 2013 | National Little Tikes Hummer Yellow
Snapped off at jack leaveing three exposed wires
Yes.Here is some info:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Oct 24, 2009 | Audio Players & Recorders
Wire broken near plug. Need disassemble a plug. How
You can buy a new plug and solder the wires to it. Leave a long enough piece of wire on the old plug to test to see which wire goes where. On the plug it should be tip+left, 2nd ring + right and the base or body is ground. Don't forget to put the shield that screws on the plug right way around on the cable before you solder.
Aug 12, 2009 | Skull Candy Full Metal Jacket Stereo Ear...
Problems with Magellan Maestro? 4040 GPS power connection
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Dec 17, 2008 | Magellan Maestro 4040 GPS Receiver
KDC-MP532U display blank
Solution from Tech48:
The problem is not the faceplate for any of you, it is inside the main unit. If you know how to solder, you can fix is very easy. First take the top off the unit, there is 1 screw in the back middle. Then take the CD player out. It has 2 screws holding it in at the front corners at the bottom of the CD deck. Use a number 2 phillips and take out the gold screws holding the CD deck in place. Then you can pull out the CD deck, and be careful not to damage the ribbon cable connected from the CD deck to the main board. The deck can just sit up and over to the left to get it out of the way for what needs to be soldered.
Look inside the main unit on the board and you will see in the front right corner a series of surface mount resistors all connected in series. Just reflow that solder on them with a small amount of new solder added and the display will once again work perfectly. That solder is very heat stressed, that is the problem. I have fixed dozens of these over the last few years. Make sure you put it back together the same as it came apart, and you are done.
Sep 19, 2008 | Kenwood KDC-MP532U
Display is OUT but everything functions....... what to do?
Nov 28, 2007 | Kenwood KDC-X590 CD Player
Wiring code for the jack?
You're right on the code, with the exception of the right and left. I'm an AKG dealer and spoke to their service department. Here goes:
White=Ground
Yellow=Left
Red=Right
To confirm this, I used a multimeter in continuity mode and tested them. This code is 100% correct.
Nov 08, 2007 | AKG K 240 Studio Professional Headphones
Pioneer AVIC-N1 Car DVD Player Logo
96 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
