Question about Microwave Ovens
Whirlpool microwave g2- touch screen. The touch screen does not work properly. If you touch a command a differnt command/menu comes up. Some menus are inaccessable.
  • Anonymous Dec 31, 2008
    the touch screen on my microwave does not work sometimes, I push several buttons without any success and then out of nowhere it will start working again, the screen flashes the microwave indicating perhaps the door is open but it is fully closed how can I fix this without having a technician take a look at it and spending more money than what the microwave is worth
  • Microwave Ovens Master
  • 9,086 Answers
We repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
Whirlpool microwave g2 - Panel lights but no text visible
It is a logic problem or at least electrolytic capacitors that dim the display too far. The display could be repaired if it isn't a ic (logic) problem if it is then you need the whole display replaced
Nov 29, 2013 | Microwave Ovens
G2 microven no coming on....has power to it
The problem is in the magnetron, or the inverter board if less than 7 years old. Part cost alone will approach or exceed the value of a new microwave oven.
Apr 07, 2012 | Whirlpool Microwave Ovens
Whirlpool gold microwave is locked how do i unlock it. it will not allow me to use the button pad
Switch off the microwave by unplugging and keeping aside for several hours.
Reconnect and see if the clock had reset, if so set the time on the panel with the touch pad.
If there is no result then try to
Press and hold menu/stop for sometime to release.
Hope this works .
Aug 27, 2010 | Whirlpool Microwave Ovens
Control panel not responding properly
this is a costly repair. when the touch pad or control pad is not working normally a new touch pad is required agin it is costly.
Feb 24, 2010 | Whirlpool MH7140XF Microwave Oven
The touch pad does not work. It displays menus
HI. this damaged touch pad board should be replaced asap. the board itself is not repairable.
Replacing the board will fix the issue.
Sep 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
G2 touch screen doesn't work any longer
You must remove the vinyl cover from the control panel and wipe down the face underneath it with denatured alcohol. It's pretty tricky depending on your mechanical caliber.
Then clean the inner side of the vinyl cover the same way. Caution don't soak the power unit just dampen a cloth, this goes for the cover also!
Aug 13, 2009 | Microwave Ovens
My g2 microven touch pad will not work, everything else works. I unplugged it and plugged back in ,shows touch error high fail 255 177 and low fail 246 0
Hello there
looks like you have a touch pad that has shorted out and is in need of replacement
please go to www.whirlpool.com and they have a technical help section ok.
best regards mike
Jul 31, 2009 | Whirlpool Microwave Ovens
Control panel on a whirlpool microwave
SOME ELECTRONIC CONTROLS HAVE A LOCKOUT FEATURE THAT IS ENGAGED AND DISENGEGED BY HOLDING A CERTAIN BUTTON FOR 5 SECONDS. LOOK FOR A LOCK PAD AND HOLD IT FOR 5 SECONDS TILL IT BEEPS.
IF NOT AVAILABLE, THE TOUCH PAD MAY BE UNPLUGGED FROM THE MAIN P.C. BOARD OR MAY BE DEFECTIVE.
ALSO, TRY UNPLUGGING THE MICROWAVE FOR 5 MINUTES
TO RESET THE MICROCOMPUTER, THEN PLUG IT BACK IN AND SEE IF IT WORKS.
AN ELECTRICAL OUTLET NOT WIRED WITH PROPER POLARITY OR NOT GROUNDED CAN AFFECT ELECTRONIC APPLIANCES ALSO.
Mar 26, 2008 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
480 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
