Computers & Internet Logo
Posted on Aug 10, 2008
Wireless mouse keeps magnifying things and I don't know how to make it stop.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Aug 10, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
180
Points
12
Sometimes when you click the clickwheel and scroll with it it will magnify things, try to click it and go up a notch or down a notch and see if that is the problem, which ever way lowers magnification is the way you should scroll, if that doesnt solve the problem then im sorry i couldnt be of assistance
5helpful
Why does the touch pad keep magnifying the
I had the same problem.
For the Dell Touchpad solution
  1. Click "Start | Control Panel"
  2. "Mouse" properties
  3. Click "Dell Touchpad" tab
  4. Look for the "Zoom" feature and disable it.
  5. That's it.
1helpful
Microsoft Wireless Laser Mouse 5000 Magnification Issue
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
6helpful
Microsoft Wireless Laser Mouse 5000: My magnifying feature on the mouse keeps tuning on and I do not know why it turns on or how I can turn it off without turning off the computer and...
1. Click Start, then select Control Panel
2. Double click on Mouse icon
3. In Mouse Properties locate the box that says "Right Side Button"
4. If this box says "Magnify (Default), Click on the drop down arrow and go down list and select disabled, the Click Apply and then OK. This should take the magnify feature off.
5. To reactivate the "Magnify" feature, go back to Mouse Properties, go down the list to "Right Side Button" . Click on the down list and go down the list and select "Magnify (Default). Click on Apply button, then Click on OK. This should reactivate the Magnify feature.
2helpful
I accidentally turned on the wireless 5000 mouse magnifier and can't get rid of the magnifier. How do I turn it off?
Normal 0 The button on the left side of the mouse when pressed turns the Magnifier on/off. Just press it again and it should turn off.
I kept turning it on accidentally so I went in the control panel and switched the Magnifier to the right side. I added that below so you can set your mouse buttons.
2helpful
Can't get magnifier off screen
First of all make sure to update to the latest driver. The problem is, the side buttons are very easy to push without meaning to do so. Right click the mouse icon in your system tray and select "Mouse Properties" select the BUTTONS tab, then disable both the left and right side mouse buttons. Click on APPLY and then OK
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Microsoft wireless notebook optica mouse 3000... model 1056
No it dont have a built in magnifier ... you will have to use the magnifier that is present in the ... Windows ... in Accesibility tools. ..
13helpful
4answers
Microsoft Mouse Model 1058 - can't undo magnifier!
Hi, I have the same problem. I resolved it. The steps are - 1.Go to control panel 2. click on mouse and it will take you to mouse properties . It will display you the Microsoft mouse 3.Go to "buttons" Tab 4.Change the option in the "small thumb button" box to "click" from "Magnifier"..the default is "Magnifier"..that is why if u accidentally push this button..it opens up an annoying magnifier.. 5. then click apply..It works
Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
2helpful
Magnifier on the wirless laser mouse 5000
Go to Control Panel and click on the Mouse icon. Then the mouse properties appears showing the mouse. In the Left column is the button settins. The bottom one is the Right Button which is set for Magnify. When ever you hit the Rignt Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
HOpe this helps. Bud
Grand Canyon Tech
Grand Canyon Tech
